  • Thread starter Deleted member 31766
  • Start date
  • Watchers 85
tracythemighty
Tracy
U.S.
2022 Ford Bronco - Race Red Base w/Sas
super easy bolt on and it took about 20 minutes, just need a ratchet
https://havocoffroad.com/p/n-fab-black-cab-length-nerf-bars/v/ford/bronco/2021/
Existing holes, no drilling required?
I do like how they look on your Bronco.
I can’t decide which I want, the ones that you have, or the stirrups from AR. I would have to get OEM rails to use the stirrups first though, but AR’s are removable in case you plan on going rock climbing so theres that. Decisions, decisions...
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
What are your thoughts on the LoD off-road signature sliders? I believe they are getting close to wrapping these up for release.
I also saw RTR has some parts dropping this Friday.
I’ve been anxious to see the GOAT Fab sliders but I’m not holding my breath. Their update has been “soon” since November.
I wish someone would create a sliders sticky like the bumper one we have. Hard to keep up with all the “coming soon” options
I had LoD SS on my Jeep, rock solid. I would recommend them. I ended up pulling the trigger on Shrockworks sliders with tread, very similar. I preferred the open bottom and they were available to order. I haven't received them yet but I will report back when I do.
Kevin W
usa
AMB 4dr Sasq Base and an Erup Green 2dr Sasq Base
Do you know what tint % you have? Looks like 35 or 45 maybe?
This is from the factory/ stock. I have not added any tints. They are clear I believe.
kevin.gt
Kevin
Canton, GA
Wow okay. The wind shield looks so much lighter. Probably the angle or where the sun is
tracythemighty
Tracy
U.S.
No, but I should be picking my Bronco up next month and I'm definitely considering them. Love em.
Did you see the stirrups from AR? I’m trying to decide between them and N-fab. Thoughts?
Richw23
Rich
Massachusetts
2021 Ford Bronco Base/Sasquatch
no drilling. i think it came with 6 bolts for each step. 2 bolts for each support are and they bolt onto the existing threaded holes in the body/frame underside
jon
Jonathan
UTAH
2003 Rubicon, 1989 Ford Bronco Eddie Bauer
Looks great
dangerzone79
O- -O
Bat Country
2022 Black Diamond & 1972 Bronco
I'm not familiar but it's really just a personal choice. Whatever you think looks best & meets the durability you require.
tracythemighty
Tracy
U.S.
I'm back again with another annoying question.... I know there has been some debate on this site about the auto stop feature. I don't like it. Every time I am pulling out of the driveway or anywhere into traffic, the Bronco shuts off.
I find it both annoying and dangerous. Has it always started up...yes, but I don't like that feeling of not knowing if it will when I am about to turn onto the main road, etc.
So many people on here talk about some button you can easily press to disable it. Where is this mythical button? Is it missing on the Base?
All I can find is to go through settings and disable it that way; however, that is a pain and it only disables it temporarily. Thanks!
theguda
IN
2013 Ford F-150
I have the Lux package so I'm not sure if this will be the same as your base. But there is a button above the HVAC controls that allows you to turn the auto start on/off.
Ford Bronco ….. 097FFB16-E2C3-4561-8449-B4D757966A3A
Moto26
Tucson AZ
@tracythemighty Pretty sure you have that same button on your Base. Yes, you still have to hit the button at the beginning of every drive, but it's a lot easier than going through the settings menu. Also, if you have Sport mode (which I think you do), selecting that mode automatically disables auto start/stop...
