Form Lighting
Lux Sponsor (Level 2)
Form Lighting
St. Charles, Missouri
Form Lighting is excited to introduce our Selectable DRL LED Headlights for the 2021+ Ford Bronco!
Our 2021+ Ford Bronco. They provide superior quality with quick and simple installation. Not only will these Bronco tail lights stand out with a more modern appearance, but you’ll also have the choice of smoked or red lens styles, a selectable red or amber sequential turn signal, and an optional startup sequence.
Modern Appearance. Unlike many other aftermarket options on the market, these tail lights were designed with factory-style optics to diffuse the light in a smooth, even appearance. The outer perimeter of the Bronco tail lights illuminates a solid bar for running and brake lights, while the lamp's interior consists of three vertical bars used for the running light, brake, and turn signal. Four individual optics provide increased reverse light output compared to factory halogen models as well!
Smoked, Not Sprayed. Both options feature a smoked outer lens, but you can choose a red or smoked inner lens. The smoked option is designed with tinted optical components, which provides a factory-quality smoked appearance - not a cheap painted look, like others on the market.
Optional Startup Sequence. These Bronco tail lights are packed with modern features, including an optional startup animation. Anytime the running light turns on, the outer C-bar illuminates in a chasing sequence. This startup sequence can easily be disabled by disconnecting the corresponding connector during installation.
Selectable Sequential Turn Signal. The startup sequence won’t be the only thing that grabs attention. These Bronco tail lights also feature a selectable sequential LED turn signal. Each time the turn signal is activated, the three inner bars will illuminate in a smooth sweeping motion outward. The best part? It's all customizable. You get to choose between a red or amber sequential turn signal! If you prefer, you can even disable the sequential feature entirely for a clean, static turn signal. Simply plug or unplug the appropriate connector on the back of the lamp.
Quad Reverse Lights The stock tail lights come with a single reverse light in each lamp, and leave a lot to be desired. With four LED reverse lights per side, the Form Lighting tails provide a substantial increase over the factory halogen lamps for more light when backing up at night.
Superior Quality. Form Lighting tail lights are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. The fit and finish of Form Lighting's lamps are superior to other aftermarket units and are sure to last for years to come.
Road Legal. Both lens color options illuminate with red or amber LEDs, and feature an integrated retroreflector sidemarker and running light, just like the factory lamp. These lamps are SAE and DOT-compliant for on-road use.
Plug-and-Play. These Bronco tail lights are completely plug-and-play for both OEM halogen and LED models with no splicing or FORScan required. Simply remove the factory lamps and these will fit perfectly in their place, without any body gaps. A harness is included for OEM halogen owners to power the brake light signal. Unlike other options on the market, these tail lights are fully compatible with the Bronco’s blind spot detection system if equipped. There are no blind spot system errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2021+ Ford Bronco LED Tail Lights!
Install Guide Here
Two-Year Warranty.
All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Click HERE to check out our 2021+ Ford Bronco Selectable DRL LED Headlights!
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Logan Z.
Form Lighting​
[/CENTER]
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
Best option I’ve seen for taillights so far!
Oldhippie
Barry
Santa Cruz, Calif.
And they still stick out to get broken buy a rock/branch…
AZ_Craig
Craig
Mesa, AZ
2024 Ford Bronco Raptor, 2023 Kia EV6 GT
Ok, now these are nice.
Agreed; some after market tails can look kind of cheap or "ricey," but these are really well done. I probably won't mess with my Raptor tails since I like how they are differentiated from the other Bronco trims, but these would be on my list if I didn't have a Raptor.
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
What's the Bronco6g Introductory Special price?
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Look great! Your links are for your headlights product though, not the new taillights product advertised here.
Ninjak
Miami
I like these. But I said I would not be spending more money on Jessabelle this year......I need to get a few things for Valencia, as she has been patiently waiting for an interior upgrade....
Draughon
Daylon
Dallas
BMW 4-Series
I don't hate 'em.
techdisaster
Not a Bronco
These look pretty nice. If I have more problems with my Oracle lights, I’ll pick up a set of these next.
Gluestick
Josh
Nashville
instagram.com
Explorer ST, Bronco Badsquatch
Love my Form headlights - on my second set after bumper car debacle. Would love to add these to back-half vehicle improvements later in the year - having been impressed by the improvement over stock signature LED headlights (and the value).
Do you have light output comparisons for the reverse lighting (lumens or lux) compared to OEM LED?
Form Lighting
Form Lighting
Form Lighting
We only had a halogen vehicle in for installation, but output improvement was substantial there. We did not get actual measurements, and I cannot confirm for the factory LED tails. I will say that the reverse light within your tails is not meant to actually improve reverse light visibility it is meant to be an indicator light to oncoming traffic that you are traveling in their direction. For any legitimate reverse light output upgrades we recommend adding a kit from our friends at Diode Dynamics who offer kits specifically for this purpose.
