- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
2021-2022 Ford Bronco 2.3L K&N Performance Air Intake System 63-2620
2021-2022 Bronco 2.3L K&N Performance Air Intake System Features:
With all of the dirt and debris that gets thrown around on the desert trails, a factory cold air intake will not cut it. Keeping your engine operating at full capacity is essential for being able to maximize your performance off-road. That is why K&N filters has come out with the 2021-2022 Bronco 2.3L K&N Performance Air Intake System for the 2021-2022 Ford Bronco 2.3L. K&N guarantees that this performance air intake system will better your torque and horsepower to improve your overall off-road capability as much as possible. You will instantly get the engine performance that comes from 50% more airflow. Not only does this aid the increased horsepower, but you will benefit from improved acceleration capability as well. Each K&N performance air intake system is built to be an easy replacement for the restrictive factory intake components that will end up holding back your off-road performance potential.
100,000 Miles Before 1st Clean
Each 2021-2022 Bronco 2.3L K&N Performance Air Intake System is rigorously tested by K&N engineers to guarantee it meets all of their high-performance standards. All of this testing assures that you will reach your targeted performance and makes sure that you are able to properly take advantage of the on-demand acceleration off-the-line, uphill, or while towing. Not only will you get increased airflow into your engine from the roto-molded HDPE intake tubing, but you will get exceptional filtration from the oiled cotton air filter. This air filter offers 100,000 of driving under normal highway conditions before the need for cleaning. When cleaning needs to be done, the filter can simply be removed, washed, and reused. No more repeat purchases of air filters in the future 2021-2022 Ford Bronco 2.3L. For protection against larger debris, a foam pre-filter is integrated into this performance air intake system design making it perfect for off-road use. Installation of this product is easy with only the need for simple hand tools. This process takes less than 90 minutes to complete and will not void an warranty requirements.
Fitment:
Does Not Fit Ford Bronco Sport or Ford Bronco 2.7L
- Enclosed air box helps protect the filter from heat in the engine bay
- Roto-molded HDPE intake tube paired with oversized oiled cotton air filter
- Engineered to provide high airflow and exceptional filtration
- Filter only requires cleaning every 100,000 miles under normal highway driving conditions
- Typical installation can be completed in 90 minutes or less with simple hand tools
- 10-Year/Million Mile Limited Warranty™
- Will not void vehicle warranty
- Made in the USA
- Does Not Fit Ford Bronco Sport or Ford Bronco 2.7L
Fitment:
- 2021-2022 2-Door Ford Bronco 2.3L
- 2021-2022 4-Door Ford Bronco 2.3L
