2021-2022 Bronco 2.7L K&N Performance 63-Series Air Intake System 63-2619
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Ford Bronco {thread} {filename}
2021-2022 Bronco K&N Performance Air Intake System Features:
  • Guaranteed to increase horsepower and torque
  • Enclosed air box helps protect the filter from heat in the engine bay
  • Roto-molded HDPE intake tube paired with oversized oiled cotton air filter
  • Engineered to provide high airflow and exceptional filtration
  • Filter only requires cleaning every 100,000 miles under normal highway driving conditions
  • Typical installation can be completed in 90 minutes or less with simple hand tools
  • Does Not Fit Ford Bronco Sport or 2.3L Models
The 2021-2022 Bronco K&N Performance Air Intake System Increases Horsepower and Torque
K&N has created an air intake system that is specifically designed for the engine on the 2021-2022 Ford Bronco. The 2021-2022 Bronco K&N Performance Air Intake System protects the engine from excess heat in the engine bay. It increases the volume of airflow into your engine with the roto-molded high-density polyethylene (HDPE) intake to add increased horsepower and torque. You will maximize the performance of your engine to be able to push your 2021-2022 Ford Bronco further during off-road adventures. This system is compatible with the K&N engine air filter to completely protect your engine from dust and debris. These filters are completely washable and reusable because of the oiled cotton filter media. The oversized, conical design allows for up to 100,000 miles between cleaning and servicing the filter. Any good off-road build is not complete without a healthy engine. It is the foundation of being able to maximize the ability of your other vehicle upgrades.
High-Air Flow with Premium Filtration
The 2021-2022 Bronco K&N Performance Air Intake System is engineered with a high-air flow design with exceptional filtration ability. This increases the airflow into the engine bay creating increased horsepower and torque. Your engine will be able to reach new limits that you never thought it could with this premium air intake upgrade. The best part of all is that this air intake system is truly easy to install. There is no additional cutting or drilling that needs to be done and the installation can be completed with just simple hand tools. The installation process takes about 90 minutes and then you will be ready to go rip up the trails. Installing this air intake does not void any vehicle warranty requirements, so you can keep your current coverage. If anything were to happen to any of the components in the air intake system, then you are also covered by a 10-year/Million Mile Limited Warranty.
Fitment:
  • 2021-2022 2-Door Ford Bronco 2.7L
  • 2021-2022 4-Door Ford Bronco 2.7L
Link to K&N Replacement Air Filter:
21-22 Bronco K&N Replacement Air Filter
Razorback
Bill
Dallas
Lincoln MKX
Interested... Any chance there's dyno numbers out there? I know Fast Intentions put out dyno numbers for their axel back exhaust. I would think the ECU would adjust for air flow keeping HP and Torque similar to stock.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
BroncoRob_Reignited
Rob
GA
2018 m240i Convertible, 2021 Bronco (pending)
Presently in stock and $50off
How do we get the $50 off at purchase? I've always used K&N products in my vehicles and would like to add this to my new 2dr badlands.
Thanks,
-Rob
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Thanks,
-Rob
That was a promotion going on last month, but I can take care of you on this, sending a PM now
Bellime
Keith
2022 Ford Bronco
Anyone share the install instructions?
Stage 3 Motorsports
Stage 3 Motorsports
Joel
