- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
New product added to the website and product review video can be seen on our YouTube channel!
2021-2022 Ford Bronco 4-Door Rock Slide Engineering Step Sliders BD-SS-300-BR4
2021-2022 Bronco 4-Door RSE Step Sliders Features:
Doing an otherwise blissful activity, off-road adventuring, you will always run into the same dilemma. Hoisting yourself into your possibly lifted 2021-2022 Ford Bronco is difficult, especially as your travels and experiences progress. This task that we all face as off-road enthusiasts seems more daunting as the years go by and a normal side step just will not cut it anymore. Luckily, Rock Slide Engineering has your back when it comes to making hopping into your 2021-2022 Ford Bronco easier for all demographics and everyday use. The 2021-2022 Bronco 4-Door RSE Step Sliders are a highly functional, trail-rated rock slider with smart motor technology that propels the power step. This feature allows the step to deploy 12" down from the body and activates when the door opens. It automatically retracts and sits flush with the body when the door is closed to retain the sleek, compact look. If you are a frequent off-road adventurist, you will not regret having this helping hand around to make getting into the seat easier and making your exterior more stylish. 10-Guage Steel Construction with Textured Black Top Coat
The 2021-2022 Bronco 4-Door RSE Step Sliders are built to be strong and long-lasting with a 10-guage steel construction. For even more protection and longevity, it is coated using an automated powder coat system that acid etches the raw base material. This primes the final topcoat which is a beautiful, textured material that adds a unique aesthetic feature to your 2021-2022 Ford Bronco exterior. The exterior is stunning, but lets not forget about the internals of these step sliders. They are made of stainless steel and aluminum that is rust resistant to keep the power step functionality running smoothly for a long time to come. If you expect to use these sliders in more aggressive off-road conditions, we recommend that you use the additional skid plate for more stability and protection. The best part of these sliders is the super easy installation. They are designed to utilize the factory mounting points and require no additional drilling to complete the installation. There is also no splicing or rewiring that needs to be done to use the power step functionality because of the stand-alone wiring harness. You will also be happy to know that you can complete all the necessary installation requirements without voiding the manufacturer warranty against installation.
Fitment:2021-2022 4-Door Ford Bronco
Does Not Fit Ford Bronco Sport or 2-Door Ford Bronco
2-Dr Version Available here
- Fully functional step and rock slider with smart motor
- Automated deploy and retraction of the sep
- Use of original equipment from manufacturing
- Textured black powder coat
- 3/16" stainless steel construction with aluminum internals
- Does Not Fit Ford Bronco Sport or 2-Door Ford Bronco
