- Feb 26, 2021
- 70
- 228
- 367
- Silverdale, WA
- Lots of Jeeps and one lone Bronco (so far)
- Base
Do you want sliders, but need steps? The Step Sliders from Rock Slide Engineering just might be the perfect fit for your Bronco. Not only are they designed for the tough trails you want to tackle, they also feature a step that drops down a full 12"s to help make entry into you Bronco much easier.
Join @Tech Tim in the Northridge4x4 DIY Garage as he installs a set of Step Sliders on a Base Squatch.
To get the Rock Slide Engineering Step Sliders for your 2021+ Ford Bronco check out the links below:
2021+ Bronco 4 Door: https://www.northridge4x4.com/part/...-rock-slide-engineering-gen-3-step-slider-set
2021+ Bronco 2 Door: https://www.northridge4x4.com/part/...-rock-slide-engineering-gen-3-step-slider-set
Add-on Options:
Slider Skid Plates 4 Door: https://www.northridge4x4.com/part/...slide-engineering-step-slider-skid-plate-pair
Slider Skid Plates 2 Door: https://www.northridge4x4.com/part/...rock-slide-engineering-step-slider-skid-plate
Door Delete Controls (one kit controls two doors): https://www.northridge4x4.com/part/...slide-engineering-step-slider-door-delete-kit
Step Slider LED Lighting Kit: https://www.northridge4x4.com/part/...-rock-slide-engineering-step-slider-light-kit
Add-on Options:
