2021-2022 Ford Bronco Fast Release Heavy Duty Splash Mud Flap Guards
Status
Not open for further replies.
ticklemybronco
Josh
Salem Ohio
2022 Bronco 4-door
Price: $239.99 onwards
Discount code : AN5 (for 5% off)
Link to buy: https://ticklemybronco.com/products/2021-2022-ford-bronco-heavy-duty-splash-mud-flap-guards
Tired of picking up road debris and rocks from your driveway? Don't know of any great solution? Do you hate the thought of drilling a bunch of holes inside your body panels? TMB has come up with the perfect solution! Our splash guards only require two small screws for each of the rear splash guards to be drilled. These are similar to the Ford Gatorbacks, but at a fraction of the price!
No need to remove your tires for installation!!
What's included in this package?
One Driver Side Front Bronco Mud Flap
One Driver Side Rear Bronco Mud Flap
One Passenger Side Front Bronco Mud Flap
One Passenger Side Rear Bronco Mud Flap
One Complete Set of Mounting Brackets (Powder Coated Aluminum, Rust Resistant)
All Hardware
Detailed Installation Video Link (Same as Gatorbacks)
How long do these take to install and remove?
Assembly and initial installation is about 60 minutes
Fast Release and Go (after initial assembly) less than 10 minutes to remove/install
What do these fit?
2021+ Ford Bronco 2-door and 4-door First Edition
2021+ Ford Bronco 2-door and 4-door Base
2021+ Ford Bronco 2-door and 4-door Big Bend
2021+ Ford Bronco 2-door and 4-door Black Diamond
2021+ Ford Bronco 2-door and 4-door Outer Banks
2021+ Ford Bronco 2-door and 4-door Badlands (w/Sasquatch and w/o Sasquatch)
These DO NOT FIT RAPTOR
What sizes are available?
Standard (shown on the Green Bronco, 9" clearance from the ground on the rears and 6" clearance from the ground on the fronts (non lifted, Big Bend)
Long (Extra coverage and recommended for Sasquatch owners. These have 8" clearance from the ground on the rears and 5" clearance from the ground on the front splash guards mounted on a non lifted Big Bend)
Extra Long (These have 6" clearance on the rear splash guards and 3" ground clearance on the front splash guards mounted to a non lifted, Big Bend) We recommend these for any lifted Bronco 3" or more.
Xtra Wide: Additional 1.5" wide for wide tires and more coverage!
We are building these as fast as we can. Please allow 3-5 business days from order date to ship date.
Ford Bronco 2021-2022 Ford Bronco Fast Release Heavy Duty Splash Mud Flap Guards Untitled
Status
