2021-2023 Ford Bronco Rock Krawler 2" Leveling Kit FB20AS
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Now in stock and ready to ship!
Message me for forum pricing!
Ford Bronco 2021-2023 Ford Bronco Rock Krawler 2" Leveling Kit FB20AS 1676662023389
2021-2023 Bronco Rock Krawler 2" Leveling Kit Features:
  • Provides 2" of lift up front for a nice level stance
  • Billet Aluminum Strut Spacer machined from Aircraft Grade 6061 Aluminum
  • Mounts to the top of the strut with Grade 8 hardware for a nice and easy installation
  • Does Not Fit Ford Bronco Sport or Ford Bronco 4-Door & 2-Door w/ Sasquatch Package
The 2021-2023 Bronco Rock Krawler 2" Leveling Kit Offers Improved Ground Clearance and Accommodation of a Larger Wheel and Tire Package
A lot of what makes a vehicle look more menacing on the road or on the trails is having extra ride height. Not only do you get a more aggressive stance, but the extra ground clearance keeps your vital suspension components farther away from potentially dangerous and damaging obstacles. The easiest and most economical way to give your 2021-2023 Ford Bronco that extra ride height and ground clearance is with the 2021-2023 Bronco Rock Krawler 2" Leveling Kit. The extra 2" of ride height may not seem like much, but it works perfectly to provide the proper ride height and ground clearance to take your Bronco to the trails and to provide the space under your fenders to upgrade to a larger wheel and tire package.
Machined from Aircraft-Grade 6061 Aluminum
The 2021-2023 Bronco Rock Krawler 2" Leveling Kit features four billet aluminum strut spacers that are machined from aircraft grade 6061 aluminum. Combine this with strong, grade 8 hardware and you have spacers that are built to take on the forces experienced when driving off-road. You get the proper ground clearance and ride height to combine with this superior strength to get a long-lasting and highly functional leveling kit. There is no trail that you cannot challenge when your Bronco is equipped with these strut spacers and the 2" of lift up front they provide that creates a nice level stance. When it comes to installation, the process is easy. Each of the spacers mount to the top of one of your struts with all of the necessary hardware included to do so.
Parts Included:
  • (4) 2" Billet Aluminum Strut Spacers
  • (1) Hardware Pack
Recommended Wheel Backspacing & Tire Size: 4.5"-3.5" & 35x12.5R17
Fitment:
  • 2021-2023 Ford Bronco 4-Door
  • 2021-2023 Ford Bronco 2-Door
