- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
2021-2022 Ford Bronco JKS Steering Sleeve Kit 9700
2021-2022 Bronco JKS Steering Sleeve Kit Features:
The 2021-2022 Ford Bronco is an off-road powerhouse, even with just the stock components. However, after getting some miles on their vehicles, Bronco owners have found out that the factory tie rod ends are a weak point in the overall performance. That is why JKS has created the 2021-2022 Bronco JKS Steering Sleeve Kit, which replaces these weak factory tie rod ends. With this kit on your Bronco build, you get reinforced steering that can handle the rigors of off-road use. The extra reinforcement allows you to take on the tough trails without the possibility of the tie rod bending or breaking. You may already have some lift added to your Bronco build, but do not worry. This kit can be applied to Broncos with a variety of lift heights.
Full Towing Adjustment
The 2021-2022 Bronco JKS Steering Sleeve Kit features a durable steel construction that is machined from cold rolled 1215 steel, 1" OD. This strong construction is what holds up when the steering pressure mounts riding over tougher obstacles. Your factory jam nut would collapse or break under the pressures of off-road use. All different ride heights of the 2021-2022 Ford Bronco are welcome when it comes to applying this sleeve kit. You get full towing adjustability to dial in the front end alignment for whatever configuration your Bronco is currently in. When it comes to installation, the process is simple and easy. You will be able to quickly get this kit installed using basic hand tools in no more than one hour.
Fitment:
Does Not Fit Ford Bronco Sport
Important Note: Works with OEM tie rods only, will not work with aftermarket tie rods
- Prevents tie rods from bending when subject to off-road situations
- Increase steering link diameter through the weakest section of the tie rod
- Works for all lift heights when used with the OE inner tie rod end
- Allows full range of OE toe adjustment
- Machined from cold rolled 1215 steel, 1" OD
- Does Not Fit Ford Bronco Sport
Fitment:
- 2021-2022 Ford Bronco 4-Door
- 2021-2022 Ford Bronco 2-Door
