- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
In stock and shipping same day, be sure to message me for forum pricing!
2021-2022 Ford Bronco ICON Tubular Rear Track Bar Kit 44200T
2021-2022 Bronco ICON Tubular Rear Track Bar Kit Features:
ICON has been a leader in premium aftermarket suspension products for the 2021-2022 Ford Bronco. There newest line of products, the tubular suspension components, are designed to squeeze the most amount of off-road performance possible from your suspension. The 2021-2022 Bronco ICON Tubular Rear Track Bar Kit is the rear track bar portion of this new line of products. This rear track bar maximizes suspension travel and articulation. At this maximized articulation, this rear track bar is designed to unlock the full benefit of your coilover suspension system. No matter what state your current off-road build is in, this is the rear track bar for you. It is a serious upgrade from the factory unit and is guaranteed to leave you in awe of your 2021-2022 Ford Bronco's new suspension capability. If you feel hesitant to invest into these rear lower links and other ICON suspension components, you can feel more confident doing so knowing that you are covered by ICON's Limited Lifetime Warranty.
Easy "On Vehicle" Adjustment
The 2021-2022 Bronco ICON Tubular Rear Track Bar Kit is a huge durability and performance improvement over the factory unit. Each rear track bar has a heavy duty PTFE-lined FK tie rod end that improves the suspension articulation. Combine this with the maintenance-free dual durometer bushings and you will create maximum angularity while isolating the noise caused by the weak factory unit. This maximum angularity helps eliminate suspension binding and allows the rear track bar to function properly. Each of these bushings and tie rod ends are CNC machined for the most precise design and fit. Each rear track bar includes a rod end adjuster sleeve that allows for adjusting the track bar length without removal or disassembly. This feature allows for correction of the axle location and dials in the tracking when ride height adjustments are made. This rear track bar is durably constructed from 1.25" x .250 wall 1026 DOM tubing that is CNC formed and fixture welded. For even more of a protective barrier, each rear lower link is finished with a multi-stage black powder coat.
Fitment:
Does Not Fit Ford Bronco Sport
Note: Lifetime warranty does not cover bushings.
- Helps to free up bind during rear suspension travel and articulation
- On-vehicle adjustable for precise track alignment using ICON’s double adjuster
- Heavy Duty PTFE-lined FK Rod End for maximum articulation
- Maintenance-free dual durometer bushing for maximum angularity and noise isolation
- CNC machined and bent 1ÂĽ" X .250 wall 1026 DOM tubing
- Multi-stage black powder coat finish
- Does Not Fit Ford Bronco Sport
Fitment:
- 2021-2022 2-Door Ford Bronco
- 2021-2022 4-Door Ford Bronco
