ICON 44200T Fits 2021-2022 Ford Bronco Rear Adjustable Track Bar Kit in stock at TMB!
Status
Not open for further replies.
ticklemybronco
Josh
Salem Ohio
2022 Bronco 4-door
The ICON Tubular Rear Track Bar helps free up rear axle movement on your 2021 and newer Ford Bronco to allow for increased suspension travel and articulation. Upgrading the track bar is essential to realizing the full benefits of ICON’s performance coilover suspension systems for the Bronco.
A massive FK Rod End at one end, along with a dual-durometer, high angle greaseless bushing at the other end yields the best combination of maximum travel and articulation while isolating and damping road noise and vibrations.
ICON’s exclusive rod end Adjuster Sleeve allows for fast, easy “on-vehicle” adjustment of track bar length without requiring removal or disassembly of the track bar. This allows for easy correction of axle location and dialing in precise tracking whenever adjustments are made to ride height.
The track bar is made of CNC bent 1ÂĽ X .250 wall 1026 DOM tubing with CNC machined threaded end and bushing housing. It has a multi-stage black pow- der coat finish.
Hit the trail with the confidence of knowing your suspension components are covered by ICON’s Limited Lifetime Warranty*.
Status
