2021 Bronco 2.7L EcoBoost Magnaflow Overland Cat-Back Exhaust Kit 19559
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
New Exhaust offering from Magnaflow has been added to the website for Pre-order. Expected delivery dates will be posted as I become aware of them.
Be sure to message me for Forum Pricing.
Frank
Ford Bronco 2021 Bronco 2.7L EcoBoost Magnaflow Overland Cat-Back Exhaust Kit 19559 1631121514607
2021 Bronco Magnaflow Overland Cat-Back Features:
  • Adds a mean, clean sound while providing improved departure angles
  • Features a high-cut, turn-down exhaust tip
  • Deletes stock tip exit locations for more clearance
  • 409 stainless steel construction
  • Complete cat-back with new tubing, muffler, and exit
  • Drop-in replacement for the factory cat-back
  • For 2.7L EcoBoost Broncos only
Gives your 2021 Bronco a More Aggressive Exhaust Note and Better Departure Angles
While the 2.7L EcoBoost under the hood of your 2021 Bronco may be plenty powerful, the sound coming out of the factory exhaust system doesn't let you know it. The Magnaflow Overland Series Cat-Back Exhaust Kit for 2021 Bronco 2.7L EcoBoosts give your hyper-tough 2021 Bronco Build a mean, deep exhaust note while also improving your Bronco's departure angles thanks to its high-cut exit and turn-down tip instead of using the OEM exhaust exits. The 2021 Bronco Overland Series Cat-Back is the perfect exhaust kit if you want to add both a meaner sound and more capability to your off-road ready Bronco build. Each cat-back replaces your Bronco's tubing and muffler from the downpipe on back, giving you excellent levels of exhaust flow while also producing a louder and more noticeable exhaust note that is sure to turn some heads both on and off the road. 409 Stainless Steel Cat-Back with High, Turn-Down Tip and Mandrel-Bent Tubing
The Magnaflow Overland Series Bronco Cat-Back was carefully designed for a perfect fit on your 2021 Bronco 2.7L, and comes with everything you need to get it up and running on your Bronco. Each Overland Series Kit features large-diameter tubing that's all CNC mandrel-bent to provide smooth exhaust outflow and excellent fitment on your Bronco. The entire kit is made out of 409 stainless steel that's resistant to corrosion in most climates and applications. The Overland Series cat-back deletes the factory bumper tip exits in exchange for a high-cut, turn-down tip design that gives you more rear-end clearance and greatly improves departure angles so that your wicked 2021 Bronco doesn't get hung up on uneven terrain, rocks, or boulders while you thunder around off-road. Each cat-back kit installs right in place of the stock cat-back system as a bolt-on replacement. Magnaflow includes all necessary installation hardware and instructions, and even backs their Overland Series kit with a limited lifetime warranty.
Fitment: 2021 Bronco 2.7L EcoBoost
For 2.7L EcoBoost only: this cat-back kit will only fit 2021 Broncos with a 2.7L EcoBoost and will not fit Broncos with a 2.3L EcoBoost or any Bronco Sport models.
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
Please let us know if they ever provide a sound clip.
Rahkmalla
NJ
15 K900
Nothing sells exhausts better than before/after videos
Slyder
Washington
2014 KTM 1290R
Camburg Racing has this system on their Bronco and doing a live feed (instagram) for it on Friday. There could possibly be a sound clip from them.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
These are now in stock and ready to ship! Message me for forum pricing if your interested.
Frank
Mr. Plow
Sergio
18' Expedition, 09' FEH, 68' Mercury Cougar
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Dang. That’s a good deal! Wish I could have saved $200. I really enjoy it!
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Looking to move some inventory, we have 14 of these in stock right now, shoot me a PM for Forum special pricing!
