Illinois 2023 badlands 4 door washout floor
Wickedbronco
Jon
Chicago
4 door washout floor from my badlands. Has been cut over center console and has two small tears under back seat that are not visable once installed. Located in Chicagoland area, prefer not to ship.
$600 OBO.
Ford Bronco 2023 badlands 4 door washout floor IMG_9340
Ford Bronco 2023 badlands 4 door washout floor IMG_9341
Ford Bronco 2023 badlands 4 door washout floor IMG_9342
Ford Bronco 2023 badlands 4 door washout floor IMG_9343
broadicustomworks
Hanging Rock, North Carolina
Just curious what you did instead.
I'm waiting for Armorlite to release the washout flooring for ours.
I have the factory one, but it could be "better".
BUFFBRONCOS
Matt
Buffalo
Are the cuts over the counsel visible when installed? Was it cut there to remove it?
Beach_Bum
Ken
St. Augustine, FL
FYI, the center strap is more of a "saddle" that is straddles the driveline and is not seen under the console. It is totally not necessary as that forward strap is located under the console and the dashboard. If you were to order the washout floor from the parts counter, you would be cutting that same strap in order to install it vs. removing the entire center console.
BUFFBRONCOS
Matt
Buffalo
thank you for that info!
