Status
Not open for further replies.
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Jeep Wrangler JLU, Jeep Gladiator, Bronco
Ford Bronco Bronco Destroyer Rear Bumper w/ Tire Carrier (10% OFF- Forum Member Discount) - LOD Offroad Bronco Dest RB wTC-4
Forum members get 10% off! Give us a call to get the discount. (765) 385-0631
LOD DESTROYER BRONCO REAR BUMPER W/TIRE CARRIER
2021+ Bronco Destroyer Rear Bumper with Tire Carrier is engineered to a higher level. The stealthy look and versatile functionality makes a bold statement, giving you a wide range of optional equipment while protecting and enhancing your Bronco on or off the trail. The optional features allow you to customize your Bronco like never before! The Destroyer Rear Bumper features interchangeable light bezels which allows you to run a variety of lights of your choosing. Orders with no lights will receive blank bezels to fill the light housing cavity. All Destroyer Carriers are equipped with high end industrial tapered roller bearings at the hinge point to decrease friction and wear, for effortless opening and closing of the tire carrier system. The Destroyer Carrier has a multitude of options. Some of the optional accessories include, Jerry cans or RotoPax gas can mounts, Trail Rack baskets, shovel and axe mounts, Air tank mounts, propane tank mounts, hi-lift Jack mounts, traction / recovery board mounts, and universal mounts so you can mount basically anything you want. All optional accessories are easily adjustable vertically up and down on the carrier with a full 14" inches of adjustment, this gives the user the ability to put them high for offroad obstacles or lower for more visibility. Trail rack has been upgraded with more adjustment to accommodate over-sized tire setups. The Destroyer Tire Carrier design utilizes a door linked and non-door linked style setup in all in one. The linked carrier design opens with the rear door of the Bronco and is equipped with a one hand quick release push button to disconnect the carrier instantly form the rear door, giving you access to the back of the tire carrier or the rear door with one easy button. This makes it easier than ever to access or remove your carrier accessories. With more room on the carrier, we added more options. Better look, higher quality, and more options!
Features Include:
-New enhanced carrier design, opens with the door and also allows the tire carrier to be opened separately from the door.
-Removable tire carrier system, can be added to the rear bumper or taken off at any time!
-Fits 40" inch tire with no Gas can mount or 37" inch tire with gas can mounts
-New enhanced industrial tapered roller bearings at hinge point on the tire carrier
-New enhanced light bezel design that prevents mud build up and easy to change lighting options
-Accommodates many different round or square LED lighting options
-High Clearance License Plate mounts
-Stronger high strength/ light weight military grade steel
-Fully adjustable accessory mounts
-Easier access and removal of carrier attachments
-Enhanced tire clearance
- Large variety of accessory mounts
-Reverse Camera mounts
-Enhanced rock crawling bumper design (less catch points)
-Built-in replacement tow hitch receiver (Tow rated same as stock 3500 Lbs.)
-High Clearance Trailer Plug mount
Note: You may need different parking sensor bezels from your Ford Dealer when installing this bumper. Please see the install instructions for list of part numbers and photos of pieces.
**All weights are of the bumper only with no options included.
Bumper is shown with upgraded accessories which are Not included in the listed base pricing, but can be added at any time. All weights are of the bumper and carrier only with no options included.
Get it here:
https://lodoffroad.com/products/bronco-destroyer-rear-bumper-tire-carrier
tock13
Tony
WA State
I gotta say, the post title doesn’t send out a good vibe on the outcome of the poor Bronco after it’s mounted. 😂
Seriously though, I’m in the market so will definitely be looking at this one.
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
I got to meet the owner at King of Hammers, spent the afternoon going out to Bronco Knoll. Super low key, super nice guys. They also make a lot of race ready SXS products, they know their stuff.
amccue90
Andrew
Illinois
2021 Badlands
The only replacement tire carrier I'll buy is one that is properly offset, to the right!
also would help different from being called a jeep
Ford Bronco Bronco Destroyer Rear Bumper w/ Tire Carrier (10% OFF- Forum Member Discount) - LOD Offroad Screenshot 2024-06-10 200026
Edeanes
Eddie
Virginia Beach
Bronco Raptor
Does the receiver match the bronco raptor specs? I want it all but need to know it can handle my large overland trailer
LangleyBen
Ben
Langley, BC, Canada
2024 Bronco Badlands Sasquatch
Ooooh, your timing is pretty good! I just drove home my 2024 Badlands Sasquatch on Friday!
Sorry if this is a basic question from a new owner: Does the tailgate swing out while the tire rack is latched to the tailgate? Basically, do I need to teach my wife anything new to operate other than "pull the tailgate handle like usual" to open the trunk if the full tire swing out is purchased? Bumper only is still a good option for me to keep things simpler too...
MannyG20
Ted
F-150
That is a nice looking fender and setup. Well done.
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Let us know if you have any questions!
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Nicely done! I think this is the first bumper mounted tire carrier I’ve seen that keeps departure angle and overall dimensions in mind. Everything else is too big!
Thanks! Let us know if you have any questions!
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
I also have one on my Rubicon. You need to emphasize that it is linked to the rear door so that means you don't have to open it first to open the rear door. Maybe pics for that.
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
LOD bumpers match the OEM towing specs set by the manufacturer.
KillerPenz
North East
If I were to venture a guess, I'd say since (2) different pivot points (swing gate vs. tire carrier), I'd say you open them separately. Though I imagine OP will have a better answer then me.
Status
