When the Bronco is in acc power is there a time limit to be on or will it shut down to battery saving mode after a few mins ?
thanks.. i have friends in Oliver springs Tn.It depends on how much power youāre drawing, but yes it will eventually shut down. You can either mash the button again, or start it to reset the time out.
messing around in Forscan was the main reason for askingshuts down after about 30 min, quite annoying when I have to wait for an hour for my daughter to get out of guitar class. Haven't spent time looking if that can be overridden in settings (or Forscan).
Can't even wash your car with the music on and not shutting down.
lol.. was just going to look for you and ask if that was a changeable setting with forscanWhen in full accessory mode (ignition button pressed but not starting engine) it will shut off (warning before hand) once the battery voltage drops to a certain point. Thereās not a set time really but itās ensuring that you can still be able to actually start the vehicle.
thanks.. was just wondering as it can be annoying... I have a 14 escape and a 19 ranger that both shuts down after a few mins.. No need to look into it unless you get bored , not really important to meI think it can be changed, I havenāt looked into it, but this would kill your battery. I know you can hit the power button for the radio and it will be active for I think up to 30 minutes. I believe you can repeat that for quite some time before battery saver will kick in
