Amazon Tube Doors Review
TheLawnDart
Austin
Las Cruces
FJ Cruiser, Subaru Forrester, Hyundai Palisade
I recently got tube doors on Amazon that look strikingly similar to the Ford tube doors, but are $430 cheaper ($820 vs $1250). I don’t have the ford ones, but here is my initial review of them after just a day:
Ford Bronco Amazon Tube Doors Review IMG_1552
Packaging:
I was immediately concerned if everything was included based on the packaging. There were some loose screws and packaging was a little destroyed. Could’ve been the mail service or the packaging, but the box is pretty heavy. The instructions (a direct copy of the Ford tube door instructions), only had 1 out of context page.
First impressions:
I could hear pieces inside of the tube doors rattling around a little when you tip them back and forth, the welds are a little…messy, and there are some scratches on the powder coat. The plastic on the handles was also a little misaligned but that was easy to fix. That being said they do feel solid and look good from afar.
Install:
Relying on fords instruction manual to help me out install was pretty straight forward. The hardest part was installing the hinges on the correct side. After installing it I thought I mixed them up because it was hard to align, so I swapped them only to find out that aligning them was just giving me a hard time. On the drivers side I had to use the shims and loosen/ retighten the hinges a few times to get the latch to align. The passengers side gave me no issues. There are some rubber “bumps” that contact the door that are non-adjustable unlike the ford ones. So a few aren’t fully contacting the door but they still feel fine.
Final Impressions:
On the car I love how they look. They feel sturdy and look very similar to the ford doors. I can’t directly compare to the quality of the Ford ones but you can definitely see some blemishes up close. If you have the Ford ones let me know how these look in comparison!
Ford Bronco Amazon Tube Doors Review IMG_1554
Ford Bronco Amazon Tube Doors Review IMG_1556
Ford Bronco Amazon Tube Doors Review IMG_1555
Ford Bronco Amazon Tube Doors Review IMG_1550
NCCarguy
Greg
Raleigh
24 Bronco
They look nice, I've been looking at this as an option, thanks for the review!
Ninjak
Miami
Interesting. Thanks for the review!
I wonder if some left over, not so perfect builds from Ford made their way to Amazon.......
TheLawnDart
TheLawnDart
Austin
Las Cruces
I wouldn’t be suprised if that were the case!
wolfeman007
JW
Matthews NC
2024 Bronco Heritage 2Dr
@TheLawnDart i ordered the fronts and they are otw. The day after ordering I was thinking about the difference between the size of a 2dr and 4dr and how I’m almost certain that their ad is wrong on amazon and these are not going to fit my 2dr. Bummer because I greatly prefer the beefy look of the factory tubes vs the cheaper options out there
TheLawnDart
TheLawnDart
Austin
Las Cruces
I do see the description where is says 2.4 door but there’s a lot of places where it mentions it is for 4 door only so I think you are right in saying it will not fit a 2-door sadly. I’ll see if I can reach out to them somehow and recommend they fix that!
wolfeman007
JW
Matthews NC
I did and they are asking me to measure the distance between the brackets on a 2D. Looks to be a bit of a language barrier. They arrive tomorrow and I’ll double check but 99% sure they are going back :(
TheLawnDart
TheLawnDart
Austin
Las Cruces
Shoot! I’m sorry to hear that. I’m not surprised about the language barrier these are certainly “direct from the factory”. Hopefully with the measurements they can make 2-door version though?
wolfeman007
JW
Matthews NC
I will eventually find some on FB marketplace, they keep popping up but are always like 3-5 hrs away from Charlotte..."is it worth driving that far to save $400ish?" The bronco accessory sickness is real :)
wolfeman007
JW
Matthews NC
just to close the loop on this and hopefully save some other readers the trouble...They arrived yesterday and indeed did not fit my 2dr, probably 6-7 inches short length wise...The good news is that I got to see how freakin beefy the factory ones are and I was impressed, they are heavy! I let the company know and hopefully they edit the ad to take out the green check marks on 2dr!
https://www.amazon.com/dp/B0DYJVL4KX?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Blakshukvw
Blue Springs, Mo
96 explorer, 99 explorer, 04 marauder, 23 bronco
What’s the purpose of the hootus looking plastic thing and can it be removed?
wolfeman007
JW
Matthews NC
Door Handle, I didnt try but it looks like you could unscrew it and take it off...
Blakshukvw
Blue Springs, Mo
Well I feel like it would look better removed and who needs a handle when there’s tubes there.
