- Adam
- Aug 30, 2021
- 355
- 4,383
- 5,844
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
UPDATE: We have stock at our warehouse on the 8X XL Linkable Kits! The 50" Kits are made to order (secure your spot in line by placing your order on our site, we ALREADY have inventory on order for these kits so when our inventory lands, your order ships first)
https://www.4x4truckleds.com/baja-designs-roof-light-bar-kit-for-2021-ford-bronco/
With a fresh new look and platform, the Ford Bronco is back! Baja Designs has a range of LED lighting kits that are all designed to be easy to install on your stock vehicle, with little to no modification required. Each kit has been carefully designed to provide high performance lighting output, increased safety, and a huge upgrade in style. Customize the look of your truck with the best performance lighting solutions available.
Baja Designs Features:
2021 - On Ford Bronco
Includes:
Carefully designed to be the ultimate roof mounted light bar kit fo r2021 Ford Bronco. The 50 Inch OnX6+ combines far reaching, high speed spot reflectors with the Baja Designs Driving Combo lens for a smooth yet intense pattern that will light up the whole trail.
Carefully designed to be the ultimate roof mounted light bar kit for 2021 Ford Bronco. The 50 Inch OnX6+ Dual Control combines far reaching, high speed spot reflectors with the Baja Designs Driving Combo lens for a smooth yet intense pattern that will light up the whole trail.
The Dual Control functionality allows for you you to control the outer two sections and the inner three independently form each other. With this functionality you will be able to meter your light bar for all situations!
This bar is equipped with BMT Battery Management Technology
The 50 Inch S8 Roof Bar Kit for the 2021 Ford Bronco is a sleek, stylish and bright LED light kit for any off-road or outdoors enthusiast looking to get the most out of their trip. Add hours of driving and adventure to your night with a reliable and high performing light bar solution that will look great on any Ford Bronco.
This kit includes a 50 Inch S8 LED Light Bar, vehicle specific mounting brackets, hardware, and toggle switch wiring harness to make installation a breeze. No cutting, trimming, or drilling is required and all wiring is pre-sized for your vehicle.
Full adjustment. Total Performance. The XL Linkable was designed for the enthusiast looking to take charge with a light package that is completely customizable for their needs.
This kit includes 8 XL Sports, Links, vehicle specific mounting brackets, toggle switch style wiring harness and rock guards. A pre-load support bracket is included to ensure stiffness in the most extreme terrain.
This kit is a turn key system for the Bronco owner that is looking to take down the night, and give a standoff appearance to their vehicle!
- Satisfactions Guarantee -30 Day Money Back Guarantee
- Limited Lifetime Warranty Complete Purchase Protection
- uService Replaceable LensesAndOptics
- ClearView All The Light, Right Where You Need It.
- MoistureBlock Waterproof, Rain Proof, Submersible
- CopperDrive Only LED Driven At 100 percent
- 5000K Daylight Less Driver Fatigue, Natural Color
Includes:
- Your Choice Of: 50" S8 Light Bar / 50" OnX6+ Light Bar / 50" OnX6+ Dual Control Light Bar / 8x XL Linkable Kit
- Vehicle Specific Mounting Brackets
- Necessary Harness (Upfitter Control or Toggle Switches)
- Installation Instructions
- This bar is equipped with BMT Battery Management Technology
- Elimination Of Flickering at Low Voltage
- Added Protection to Vehicle Wiring and Systems
- Protection from Dangerous Current Spikes
- Lumens:39,430 Utilizing 30 Cree LEDs
- Wattage/Amps:355W / 28.2A
- Dimensions:50 inch x 4.29 inch x 2.69 inch
- Weight:18.65 lbs
- LED Life Expectancy:49,930 Hours
- Front Lens:Hard Coated Polycarbonate
- Housing:Aircraft Grade Aluminum w/Mil-Spec Hard Anodize
- Bezel:Billet Machined Aluminum
- Hardware and Bracket Material:Stainless Steel
- Exceeds MIL-STD810G (Mil-Spec Testing)
- Built-In Overvoltage Protection
- IP69K (Waterproof up to 9ft and Pressure Washable)
- IK10 Compliant (Mechanical Impact Testing)
- Lumens:39,910
- Wattage/Amps:346W / 28.2A
- Weight:11.45 lbs
- Lumens:31,750Utilizing 40 Cree LEDs
- Wattage/Amps:300W /20A
- Dimensions:50 Inch x 3 Inch x 1.6 Inch
- Weight:10.75lbs
- Lumens:25,200 Utilizing 32 LEDs
- Wattage/Amps:208W / 16A
- Housingowder Coated Cast Aluminum
- IP69K (Waterproof, Submersible to 9ft)
