Belltech Lift Kit Available
Caleb@PandaMotorworks
Caleb
St Louis MO
We had a customer cancel his order for these, so now we have a set available. These are IN STOCK and READY TO SHIP, no waiting! These tend to be on backorder so this is a great opportunity for someone that wants a great quality lift kit, but doesn't want to wait on backorders.
Message me if you are interested and ill hook it up with free shipping and a free Panda Motorworks T-Shirt!
Belltech 2021+ Ford Bronco Performance Handling 0in-4in Lift Lift Kit
Ford Bronco Belltech Lift Kit Available ezgif-5-20fcd95b56
Need the ultimate in ride quality, handling, and ride height adjustability? Belltech coilover systems are the answer, providing complete height adjustable replacement shocks and springs in an application specific complete coilover unit. Belltech now offers a complete solution for the front end of your strut equipped Truck or SUV. Increase grip, reduce body roll, all while retaining the daily driven comfort you require. Each kit consists of two threaded large 60mm body performance dampers with the option of independent compression and rebound damping force adjustability. Belltech coilovers come preassembled with matched performance coil springs, Aluminum spring perches, progressive rate open cell bump stops, and plastic dust boots.
Fits: 2021+ Ford Bronco 4WD
The Ford Bronco is back, and with Belltech's new, brilliantly engineered, 0" to 4" complete lift kit, it is better than ever! Our kit enhances your Bronco's ride quality and outperforms other lift kits on the market. The Belltech 2021+ Ford Bronco lift kits were introduced at SEMA 2021, and vehicle enthusiasts raved about their striking appearance and superior quality. Belltech engineers have designed the 2021+ 4WD Ford Bronco lift kits to a T, improving ride quality and making advanced safety their number one priority. Our kit includes 2.4" (60mm) large-bodied, finely tuned, height-adjustable Trail Performance coilovers in the front and rear, which house increased amounts of oil and employ a low-friction design to give you perfect damping throughout your journey. Our independent 35mm rebound and compression valves work to give you more precise damper tuning, and the 20mm hardened chrome piston rod lends extra strength and durability. Belltech linear springs are made of cold-formed high tensile steel and are powder coated red to give them an eye-catching yet protective finish. The coilovers feature our double-wall high durometer vulcanized rubber bushings, which reduce noise, vibrations, and wear. Each coilover uses a threaded damper body and spring perch to offer height customization in from 0" to 4" of lift. To deliver optimal bump stop engagement, we include a progressive rate polymer, open-cell bump stop.
We reduce body-roll by including a cold-formed, solid steel 1 3/8" front anti-sway bar. It possesses 3-hole adjustability so you can add or reduce the amount of tension depending on the type of ride you intend to achieve. In the rear, we also involve a 3-hole adjustable, 7/8" cold-formed solid steel anti-sway bar, offering increased stability and a sport-like ride quality.
Our kit improves handling, adds clearance, and gives you the option to use larger tires and wheels, expanding your contact patch. The Belltech Ford Bronco kits have undergone rigorous testing in the most extreme circumstances to provide you with the best high-performance, heavy-duty suspension option you can find. Your 2021+ Ford Bronco will be the envy of all who desire off-road adventures since Belltech suspension will transform it into the ultimate trail climbing machine! Our kit features easy installation that requires no cutting or welding, so you are promptly back behind the wheel. Our Belltech Suspension lift kits also feature a lifetime warranty - so you are covered, no matter what.
  • Precision designed and engineered in the USA
  • Lifetime warranty
  • 2.4" (60mm) damper bodies
  • 35mm independent rebound and compression valves
  • 20mm hardened chrome piston rod
  • Front 1 3/8" adjustable anti-sway bar
  • Rear 7/8" adjustable anti-sway bar
  • Uniquely engineered for your 2021+ Ford Bronco 4WD
  • Includes custom engineered front and rear height adjustable Trail Performance coilovers
  • High tensile steel spring, powder coated for longevity
  • Multi-sleeve, vulcanized rubber bushings
  • Improved ride quality over factory
  • Maintains factory turning radius and track width
  • Easy installation
  • Progressive rate polymer, open-cell bump stop
Wheel/Tire Fitment Information:
35x12.5 Tires on 17x9 Wheels (6" BS)
Trimming may be required.
