Best Dash Cam recommendations?
TiffyCha
Tiffany
OHIO
2022 Bronco
Answers o these questions depend on your intended use mode. Mine is strictly for security and accident events, so I never look at the videos and never download them. I wanted something that has good resolution for license plates, at night whenever possible. Wanted front and back recording in case someone reaerends me so 2ch recording was a must. I wanted recording while parked so a hardware capability was a must. Running wires to the back of the bronco is a bit of a PITA particularly across the A pillar so thin cables and compact connectors were highly desired.
I have a small picatiny BYOD rail on the dash on the off chance that I ever want to record something "for fun".
PS 3ch recordings are mostly for Lyft and Uber drivers.
What camera did you go with? These are all the exact reasons I need one...to protect my investment.
BleednBlue
Rich
Wentzville, MO
2023 Ford Bronco; 2018 4Runner; 2008 GX470
I went with the Garmin mini 2 for one main reason -> NO GPS. No GPS will help ensure the video cannot be used against you, i.e. no speed detection.
TiffyCha
Tiffany
OHIO
2022 Bronco
Nice! Thank you, I never thought about that aspect!
GroovyGeek
Boyan
'23 Bronco BD
Pictures please of your rear mounted camera.
It is stuck to the middle of the tailgate window, not much to see. Sure, you can't remove the hard top without disconnecting the cam but I am 101% sure I will never ever want to do that. 20 years with a Wrangler has made that conclusion pretty firm.
GroovyGeek
Boyan
'23 Bronco BD
You can turn disable the GPS in software on the Viofo 139 pro
GroovyGeek
Boyan
'23 Bronco BD
Viofo 139 pro
Latest sensor tech
Good image quality at night
No pointless screens to take up space
Tiny connectors and RF cables for easy routining
Up to 3 ch recording
The firmeare is glitchy and a pita to download the images but I am hoping to never be in an accident and need to do that. And if I do I can just pull the SD card
adam1991
VW GTI (2)
This right here. I've turned GPS off on the el cheapo unit I've had for a few years.
One other thing: beware audio recording. If you don't know what I'm talking about, do some research or contact a lawyer.
adamruiz2001
SoCal
Ford SVT Lightning
GroovyGeek
Boyan
'23 Bronco BD
This. Most dashcams will record audio by default. You absolutely do not want that feature enabled. Depending on how lead footed you are you may or may not want GOS enabled. Though to be honest disabling GPS makes speed determination only slightly more difficult. There are plenty of objects on the roadside with a known fixed distance between them, back calculating speed is just a matter of basic math.
