I'm in the market for a small dash cam to put on the dash,any recommendations? Thanks
newclubfront
Home
Car
My dash cam is a lot bigger so it blocked the auto-dimming sensor on the back of the mirror so it would think it's night time during the day. I had to move my dash cam down. Looks like I need to invest in a smaller dash cam. Only downside to this setup is I can't use the sunshade with a dash cam stuck to the windshield.
skweaz
Toyota Highlander
You can use a sunshade with the Garmin mini:
Ford Bronco I'm in the market for a  small dash cam to put on the dash,any recommendations? Thanks 1659035672248
Also, Garmin's constant power cable is great and a super simple install. You can run it via the headliner all the way down to the ODBII port. You only have to remove one screw on the driver-side shade and the driver side Bronco handle, tuck it in and re-assemble.
I used this cheap set to assist with some of the tucking:
https://www.amazon.com/gp/product/B07D43PG25/
Moto26
Tucson AZ
How does the Mini handle sitting in the direct sun all the time? I know the Garmin publicity says itā€™s made for the heat, blah, blah. But Iā€™ve had so many electronic devices that just couldnā€™t handle the AZ sunā€¦
skweaz
Toyota Highlander
So far, so good here in TX, no issues.
Allenm7
Allen
Los Angeles
Ford bronco
Most good or higher end camera have capacitors instead of battery. They work great in extreme temperatures. My Garmin hasn't failed in very hot weather. Also make sure you get a good sd card too. SanDisk endurance is good. They're meant for constant rewrites and more extreme weather.
MyATV
ATL
Just ordered a Garmin Mini this morning. Ordered it off their website, as it was same price (to the penny) as Amazon. No shipping, just tax.
I'm hoping to not mount it to windshield, as I have tint - which could get dicey should the need arise to remove it. We'll see.
