I was wondering if you installed the Bestop Bimini Top, could you leave it on with your hardtop installed. If this works lets me know and if not is there a better solution? Thanks in advance!
Yes for the four door. Was hoping to find an easy solution. Thanks gor your reply!Wondering this too on the 4 door. I believe the answer is yes but I had a hard time finding definitive info or pictures.
GearShade seems close to coming up with a solution to theirs as well:
https://www.bronco6g.com/forum/threads/gearshade-sunshade-tops-for-broncos.30910/unread
Well done! Thanks for the reply!Yes, the BesTop Bikini top can remain installed with the hard top on. Says it in the instructions as well as the proper name.
No problem. I would have posted pictures but I'm still awaiting the Bronco to install it onWell done! Thanks for the reply!
Concise and quick! Thanks so much!Yes. Currently have it installed and hard top on. The mesh top was one of first options I added. Just roll back the front and put top back on. Fits perfectly and super easy.
so the front of it needs to be unattached and rolled before the hard top can go back on?Yes. Currently have it installed and hard top on. The mesh top was one of first options I added. Just roll back the front and put top back on. Fits perfectly and super easy.
The 2 clips that attach in middle. Where front panels attach. Will take pics and post. 1 min is all it takes to in clip. Non issueso the front of it needs to be unattached and rolled before the hard top can go back on?
