Buckle up winch mount
98infinity
Alberta
16 F150, 20 Road King, 22 Bronco
mcinfantry
Lee
Louisiana
Badlands 2 door
Don’t all the spoonbill mounts do that?
BroncoAZ
Mitch
tractorcrusher
Curtis
DFW, TX
Full time youtuber selling chinesium junk winch mounts and other cheap parts, no thanks.
yeah I don’t think I’d trust Chinese steel to hold a winch and pull the weight of a vehicle.
98infinity
98infinity
Alberta
So this is the mabett winch mount then?
NorthTexasBronco
Wichita Falls Texas
2023 Outerbanks 4 Door, 2023 Wildtrack 4 Door
Does anyone have this winch mount...looks like the red tow hook mounts reduce the approach angle alot.
https://buckleupoffroad.com/product...w-modular-bumper?_pos=39&_sid=8f0a49b3a&_ss=r
So an honest review so far is that it is very heavily built with good welds, install instructions could use a little work but if you have decent knowledge of wrenching you will be fine.
The finish is painted, but would probably last a couple of years, with the exception of the painted zinc hardware (the 6 bolts on top the rest is stainless). The beautiful part is that is Adaptive cruise, parking sensors and front camera all work with no issues.
I chose to go with 12k Badlands Apex winch, well because it was easy to get and return if needed. Also I figured if Matt's off-road recovery uses them on their recovery wrecker then it is probably good enough for me. I also looked at Smithy Built and Warn Evo (Evos seem to have issues).
One thing to note is this mount goes around the modular bumper but does not bolt to it. It is instead sandwiches the bumper from the front. I didn't do any frame reinforcement but I probably should, because I could see the amount of leverage being great with the 12k winch.
Only issue I had was the Aluminum Fair lead that came with the winch had to be mounted upside down to clear the sharp bend of the camera mounting bracket.
Ford Bronco Buckle up winch mount 20230929_095810
Ford Bronco Buckle up winch mount 20230928_121145
Ford Bronco Buckle up winch mount 20230929_095830
Ford Bronco Buckle up winch mount 20230929_095817
Ford Bronco Buckle up winch mount 20230928_121144
Ford Bronco Buckle up winch mount 20230929_095837
Ford Bronco Buckle up winch mount 20230928_120331
