- Thread starter
- #1
If you like the stock wheels can you put a bigger tire on them? Can you put 33's on the stock Big Ben wheels thst come with 32's?
I'm assuming the BBs are 7.5? Would that limit the upgrade to 275s?If you go to the manufacturer website of the tire you’re looking at, they always list approved wheel width for all of their tire sizes.
For example, most manufacturers list a 12.50” or 315mm width tire as an approved wheel size of 8” to 12” wide.
I think the overland concept Bronco makes it obvious that 35s will probably rub without a suspension changeYes you can absolutely add larger tires, the rim width will allow for it. The issue you'll most likely have if you go over 33's is related to the suspension and rubbing you'll have on parts of possibly the suspension, bumper, fenders. Given that the 35" tire pkg comes with a higher suspension, IMHO that means Ford knows that 35's on a lower suspension has a chance to rub.
yes and no. depends on the width of the tire you want to run. tire hight is not is not limited by wheel size tire width is.If you like the stock wheels can you put a bigger tire on them? Can you put 33's on the stock Big Ben wheels thst come with 32's?
