Does the Baja Designs 8XL Light Bar Whistle While Driving?
ryannshit
Ryan
Castro Valley, CA
youtube.com
2021 Bronco Badlands 2.3 L Manual
How did you run power for that?
I followed Motoroso's method by drilling a hole on the passenger side mounting point and routing the wires behind the glove box and firewall to the light bar wires for aux switch #1.
It's not crazy hard but Ford didn't provide much length on the wires you need to connect to do the routing portion. Once finished it's definitely the cleanest option. Didn't want wires running down the outside windshield. I really like how it turned out.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Ford Bronco Does the Baja Designs 8XL Light Bar Whistle While Driving? 20221231_112159(0)
We use the KC HiLiTES wire hider on our installations. Simple, non-permanent and no drilling required. You don't even realize it's there usually
https://www.4x4truckleds.com/kc-hilites-universal-wire-hider/
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Anyone have any pictures of an install using this? Not a fan of drilling a hole in my vehicle. Looks like Baja also has a kit. Might be cleaner look to cut the sheathing and tuck the wires in between the windshield and pillar.
Whatcha mean Baja also has a kit? What kit?
Here is a photo of the KC Wire Hiding system on our demo truck... can ya see it :)
If not, look on the passenger side
Ford Bronco Does the Baja Designs 8XL Light Bar Whistle While Driving? XRGB2 (small)
Ford Bronco Does the Baja Designs 8XL Light Bar Whistle While Driving? XRGB1 (small)
Ford Bronco Does the Baja Designs 8XL Light Bar Whistle While Driving? XRGB3 (small)
Sighlense
Upstate NY
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Wow. As one of Baja Designs biggest dealers im surprised I never heard of this. Looks to be the exact same thing.
KC is $20.99 though and Baja's is $29.95
Baja includes some adhesive promotor though, but even still, we keep a big jug of that ourselves and we've never used it on the windshield wire hiders (we use them on bed rails and other things in the beds that are going on aluminum).
Sighlense
Upstate NY
I'm thinking about cutting the sheathing and tucking the wires in between the windshield and pillar with black wire on top and silicone. Next problem is the amount of exposure up top with a 40" bar. I REALLY don't want to drill.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I thought about doing that, but this is so much easier.
Don't drill into your roof, pointless. If you ever remove the light bar, well now you have a hole
This is a Baja Designs thread though... they don't do a 40" up there...
CarbonBronco
Tony
Socal
99 Toyota $runner
I drilled into my roof to run the wire leads for power. As long as you seal with a clear waterproof silicone you’ll be fine I‘ve had my bar on for months and since we have had this crazy amount of rainstorms in socal we have had a lot of rain. I love my 40” onx6+ and how it sits on my bajarack roof rack.
@Baja Designs I’ve got a question which I shot you guys an email for but I figure I can get an answer here too. Is there a certain way to clean the s2s or squadrons? To keep the housings from fading and turning dull? Also are the new squadron saes ready to go? I’m ready to send mine back to swap to the new squadron saes!
Ford Bronco Does the Baja Designs 8XL Light Bar Whistle While Driving? AED6E444-7736-49EC-BB43-0554C36A40CA
Ford Bronco Does the Baja Designs 8XL Light Bar Whistle While Driving? A611F81F-DA22-4135-8F96-6C9B17218EE7
4x4TruckLEDs.com
Adam
Lindenhurst, NY
The new ones will be out end of the month, sometime next month. We'll have them in stock at our warehouse when they are released.
As for the S2, those look to be older stock (which a lot of people like). They have the older bezels. The newer bezels are shinier and have a different finish on them to prevent that from happening.
Botz82
Joseph
Toronto
I can confirm I have a strong whistling noise on my set. Any solutions to mitigate this?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Nothing you can do. That's what happens when light bars are on top of the roof.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
exactly why I went with bumper LED. This is present on nearly all roof mounted light bars. You can try to minimize it but........Soft top ends up vibrating like crazy as well.
