Fender Delete Increase Wheel Clearance?
wilbersk
Sean
2023 Bronco Raptor
Does anyone know if a fender removal/delete will officially increase clearance for bigger tires?
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
After seeing the non squatch flares in person they arent as bad as i thought they were going to be. I was all about deleting, or waiting for a smaller profile aftermarket, but now I might be ok with them.
But as said they aren't usually the rub problem. crash bars inner fender, and a-arms are the culprits.
wilbersk
wilbersk
Sean
2023 Bronco Raptor
It’s usually not the outside that affects clearance, it’s the inside when you turn the wheel that will rub on something...
Ahh ok. Wishful thinking! Haha
Whelan007
Austin
2019 Jeep JL
On the Jeep Wrangler JL High top fender flairs do allow for larger tires. I don't think we have a clear answer on the Bronco yet if different fenders or fender delete will allow larger tires.. Larger tires will require a higher wheel offset and may need crash bar modification even with a lift.
Whelan007
Austin
2019 Jeep JL
With my Jeep JL Sahara I was able to go from 32 to 315/70/17 which are 34.4 in tall without a lift or other modification. It does hit the fenders on bumps but since I don't off road I can get by with it.
I was going to change to high profile fenders but have done fine without on road for 15,000 miles.
wilbersk
wilbersk
Sean
2023 Bronco Raptor
Honestly I just hope the Toyo Open Country MT’s in 315/70/R17 fit. They are 34.65” tall and 12.72” wide
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
Honestly I just hope the Toyo Open Country MT’s in 315/70/R17 fit. They are 36.65” tall and 12.72” wide
Toyo's website shows the height of that tire at 34.6" so basically the same as a squach tire.
Low Hammer
Idaho
10th gen F150
Except with
But on the Bronco you can replace not just the fenders, but also the body panels. I mean seriously.
Ford Bronco Fender Delete Increase Wheel Clearance? 1619591310397
Ford Bronco Fender Delete Increase Wheel Clearance? 1619591334953
Ford Bronco Fender Delete Increase Wheel Clearance? 1619591210557
I guess we will know the ins and outs of the options soon enough.
Clips taken from the SEMA build
