ForScan after previous mods.....
Bronceaux
Johnny
Alabama
2021 Ford Bronco Base Sasquatch, Chevrolet Z71
I previously used ForScan to add GOAT modes, stop Auto start/stop, and remove double-honk. I am using the same device, but a license registered to my buddy, on my laptop (different from the one I used to make my mods). I want to make stereo changes this time. If ForScan displays a window saying "Found recorded profile(s) for this or similar vehicle(s). Would you like to load the selected profile? Should I select yes? I do not want to mess with previous changes. If I select no, is it going to revert to "As built" configuration? If I am asked if it is the first time I have ran Forscan, and I click "Yes", creating a new profile, will it save the current configuration as my new profile? Thanks in advance.
sportcoupe
Georgia
2023 Bronco
I always delete the vehicle profile in forscan and create a new one each time I make a change, which isn't often.
I would especially delete all profiles if I was going to make changes to someone else vehicle. Something I'd never do anyway.
Profiles do not save your modules programming, just the vehicle.
Bronceaux
Bronceaux
Johnny
Alabama
To confirm, if I start by deleting all profiles, and when asked if it is the first time I have used ForScan, I select yes, it should save the new profile, without affecting any previously revised modules? Just double-checking.
