Help locating a specific fuse
TraumaJoe
Joseph
Roseville, CA
Jeep Wrangler Unlimited Rubicon JK
Can anyone tell me what fuse would be associated with the interior lights turning on when you open the door?
after installing the IAG interior lights, which worked and now all of a sudden doesn’t work.
I’ve checked the button where the map lights are and that is not the problem. My interior lights come on when I push the button in the overhead console, but not when I open the doors.
mid anyone know what fuseI may have blown, I would appreciate any help.
thanks!
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
All of the interior lights are fed from the Body Control Module. There are 4-5 different fuses that power the BCM, there isn't a fuse specifically for the interior lights.
TraumaJoe
TraumaJoe
Joseph
Roseville, CA
The lights inside work, it’s whatever controls them coming on with the doors opening. Wouldn’t that be a different fuse?
RagnarKon
Bryan
New England
Nope, it's all controlled by microprocessors within the BCM.
The BCM get a signal directly from the door latches. Open circuits from the latch mean the door is open, grounded signal means the door is closed.
TraumaJoe
TraumaJoe
Joseph
Roseville, CA
Ok, thanks so much for the info, i appreciate it.
Ground_zero298
Scs michigan
Stickerfab sells fuse panel labels for us. They have one for both boxes. Really handy.
