Ok, brand new to beadlocks so apologize for what may be a stupid question.
When periodically checking the torque on the bead locks is it adequate to do a quick check with the tire mounted? Do you need to jack-up the wheel to get the weight off the tire every time? Or, do you guys actually de-mount the tire?
Also, I've read that a lot seem to only check when changing oil or rotating. I assume that initially they should be checked a bit more often until they "seat" well?
Any advice is much appreciated.
thanks
thanks
