help with fog lights
Ixr
2022 2DR BASE SAS
Im going to install fog lights in my standard(base/plastic) bumper. I plan to wire them to aux switch 2, Im not sure what is needed to do this though. Is there a harness you need to plug fogs into and then wire to the aux wires?
If someone can tell me the simplest way to do this I would appreciate it.
Sgt Badlands
Midwesr
This guy does a nice install to the aux switch. Very detailed.
Look up the colors of the aux cables. I believe aux 2 is the green/brown wire.
  • Like
Reactions: Ixr
SPVPARTS
Lux Sponsor (Level 2)
Greenwood, IN
specialtyperformanceparts.com
Ford Raptor/Bronco/Mach E
Hey There!
Please give me a call or text me and I can help you with this.
My direct line is (317) 934-6778.
We have a complete line of patented plug and play harnesses and connectors that will make your install a breeze.
Do you already have the lights you are wanting to install?
If not, I can help you out with that with discounts on everything, including the lights. If you do already have your lights, I can just grab the info from you regarding what they are and what, if any, connector style is on them so I can match it up with the corresponding connector adapter for our harness system.
Here is a link to our YouTube Channel, so you can check out some of the videos we have on our wiring: SPV Parts with John Trischler - YouTube
And if you don't have your lights already, these tend to be pretty popular for the standard bumper and can be completely plug-and-play with our wiring.
2021+ Ford Bronco Rigid Industries 360-Series Pro SAE Fog Kit (White F (specialtyperformanceparts.com)
Anyway, I'd be happy to help you and answer all of your questions. Feel free to reach out to me by call or text, or you can message me on here.
Have a great day!
Sidney @ SPV Parts
(317) 934-6778
[email protected]
Ixr
Ixr
2022 2DR BASE SAS
thanks for the replies, no idea why the cupra video didnt show up on my youtube search as ive watched a few of his videos to help me install things in the past.
It looked like I expected and just ordered a generic light harness to cut up, the video cleared up my confusion.
CartierChiro
Xavier
Watts, California
2016 Kia Forte, '96 Impala, '64 Impala
Anyone have tips on what the process looks like without aux switches (base model) do I need to get a new controller for the exterior lighting?
Ixr
Ixr
2022 2DR BASE SAS
Ixr
Ixr
2022 2DR BASE SAS
Ford Bronco help with fog lights fo
Got fogs installed. Was pretty straight forward, most annoying part is running the wires down to both lights. Took about 45 min.
part list to get it done for anyone interested
https://www.amazon.com/gp/aw/d/B07FY895TN?psc=1&ref=ppx_pop_mob_b_asin_title
used this and just cut off all the relays and wired into the purple wire and then connected to aux switch one using a quick disconnect fitting so I can change if needed.
Trim panels with the cutouts:
https://www.amazon.com/gp/aw/d/B0D3LQ2VM8?psc=1&ref=ppx_pop_mob_b_asin_image
I went with these fogs but there are a lot of cheaper/alternative options :
https://www.amazon.com/gp/aw/d/B09X25LF6C?psc=1&ref=ppx_pop_mob_b_asin_image
