this^^^ had this except the other way on a ram I owned. After the bilstein lift I had to buy an adjustable bar. Took me a few hours but I got the rear axle centered again. With that bracket the bar may be pushing your axle to that side.With the lower lift you don't need the trackbar bracket which is probably pushing the body to the driver's side. When you decide what final height setting you want to run at, that will determine if you need the bracket or not.
