Install ideas for Panda Motorworks Power Module?
Cobrafang
Thomas
GA
Looking for install location and mounting undead for the power module. The video just shows it laying on the fuse box…..they provide plenty wire ties but wanted to see what others have done….especially so you can remove with out a trace. Thanks in advance!
Cobrafang
Cobrafang
Thomas
GA
Ok so I went ahead and drilled 4 small holes through the fuse box cover that allow two zip ties to pass thought the holders on the bottom on the module. I also went and purchased a spare fuse box cover so I can return to stock. 35 ish bucks from ford parts. So basically it sits right where Panda places it in their install video. I plan on getting some black silicon sealer to fill in the holes for dust/water protection. I will post a pick tomorrow.
Crash98
Viet
Bremerton, WA
2017 Ford F-150
I just used velcro strips.
Morganstein
2021 Ford Bronco Badlands
I just used thick double sided tape. It's been on there for quite a while and hasn't moved yet.
sniffHound
W
Mississippi
Ford Bronco
Asking a question not related to your question.
Can you feel the performance difference?
Cobrafang
Cobrafang
Thomas
GA
So I also have mounted the K&N cold air kit and the Panda power module, with the power module in race mode and the truck in sport mode with 2H yes...it is about a 50hp diff if you believe the numbers and dyno charts and I can feel it. But because I am MPG freak, I don't drive it around town in that mode, plus tires are so dang expensive. So back to power mode econ and bronco mode econ for grocery getting. :)
sniffHound
W
Mississippi
Ford Bronco
Need to reinstall. Love the Panda.
