I have installed a small power winch in the ceiling of my garage in order to easily remove my 2 door hard top. I put a strap on each side of the top from front to back. When I lift the top, if it is not perfectly balanced the straps slide a bit, making the top tilt upwards or downwards on the front/back.
Has anyone run into this and how did you attach the roof to a lift so it doesn't shift when lifted? I don't see a way to attach a strap to each corner, which would make this easy?
