- John
- Jul 9, 2022
- 55
- 262
- 398
- Greenwood, IN
- Website
- specialtyperformanceparts.com
- Ford Raptor/Bronco/Mach E
- Badlands
For a limited time we are offering 20% off our SPV triple fog kits with Diode Dynamics lights as well as our SSC2 Rear kits.
We will be adding our OEM Bronco Raptor kits here soon as well.
The Fog kits come in SPORT, PRO or MAX
The Rear kits come in SPORT or PRO
Here is a link to the triple kits with amber backlight for the Modular Bumper -
https://specialtyperformanceparts.c...-w-amber-backlight-including-brackets-harness
And here is one for the Rear Kits with Red Backlights -
https://specialtyperformanceparts.c...red-backlight-rear-led?variant=44687659073768
Remember. Our kits are like NO OTHERS out there. Our patented Harness system (Which each kit includes our harnesses) Are the first and only truly plug n play modular system. Allowing you to simply plug in multiple harnesses, splitters, interconnecting vehicle adapters, etc. PATENTED - US 11,699,537 B2
In addition, we use the HIGHEST quality components and our harnesses have an insulation that is industrial grade. Exceeding the 105 deg C rating of all others we have see out there. Ours have a temp rating of 200 Deg C which is close to 400 Deg F. That means you don't need to worry about wires melting. Heat from the engine and other factors.
Check out the heat test we did compared to the other wiring out there -
You can also check out how our harnesses work for your Fog kit in this video compared to the Standard Diode Kit -
We follow the same guidelines when it comes to our brackets. We only use the highest grade stainless steel AND we don't stop there and give you zinc plated steel bolts. Nope. All the hardware is ALSO stainless steel.
While we can assure you there is NOT another kit out there with lights, harness and brackets that meet or exceed ours. We encourage you to reach out if you find something similar for a lesser price and in most all cases we can meet or beat the price for you. This goes for any light kit.
Last, if you are looking for individual Lights. Reach out. We still have some additional overstock and if you let us know what you are looking for. We can let you know if it is on the list. We stock and carry a ton. We just have some extras of some part #'s. That's about all we can say.... if you can take a hint. Shoot us an email or a PM to inquire.
SPV-
info @spvparts.com
SPV-
info @spvparts.com
