Looking for 2025 trailer hitch module
birdy1450
Unberto
EgEg1040!
2025 Ford Bronco Outerbanks
I’m trying to see if anyone knows where I can get the trailer module for my 2025 ford bronco out banks. I’ve been looking around but cant find anything on it since I already have the hitch and the 4/7 pin wiring connector. Thanks!
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Quatermain
Idaho
2025 Bronco
It is my understanding that the 2025 models are all pre wired. That was the case on my 25 Badlands that i just did an install on using this video: . You will still have to go to the dealer for a programming update.
birdy1450
Unberto
EgEg1040!
Did you buy the kit from ford? Because I don’t need all of it I just need the module
Ford Bronco Looking for 2025 trailer hitch module IMG_6726
Ted Miller
Ted
Phoenix, AZ
2025 Bronco Outer Banks
You can't buy just the module for 2025 and up models. You have to buy the whole tow hitch kit.
Quatermain
Idaho
2025 Bronco
OK, I am with you now. Yes I bought the kit from Ford and the module was included with it. . Part # VS2DZ-15A416-C . So that module has to be available from Ford , via Lumen.
Ted Miller
Ted
Phoenix, AZ
You sure would think so, but I was never able to find it and the parts department at my local Ford dealer wasn't either. So now I have a brand new OEM hitch that I have no use for.
Quatermain
Idaho
2025 Bronco
Makes sense you can get one separately since the module is very clear about not dropping it! It is the most delicate part so Ford has to have a way to get replacements. But yes, the parts departments seem to be behind the curve on this kit. Maybe contact someone in Service?
The Bearded Axeman
Zach
Rochester, NY
2026 Ford Bronco
What did you have to ask the dealer to do the programming? I've been calling around my area and no one seems to know what I'm talking about. I downloaded the iSheets, hoping I can hand that to a technician and they can figure it out?
Quatermain
Idaho
2025 Bronco
That's what I was told by the dealer when they sold me the hitch kit. I haven't done it yet. it strikes me that the dealer's are in limbo on the hitch kit, and the '24 models' seem to be the problem with this particular kit. .
bradform
Morris
Dublin, GA
2002 F-250, 2003 F-150, 71 Ford Bronco
Hey guys. Thanks for the detailed info in this thread. Quick question for you all. I installed a hitch and a sole 4-pin wiring harness from CURT on my 2022 4-Dr Base about a year ago. I now need to add a 7-pin setup to my rig. I assume I need to start over with Ford: VP2DZ-15A416-A and then simply add a separate brake controller for trailer brake management? Do you think my rig was pre-wired and includes the module referenced above from the factory? I would guess not.
