Lower control arm
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
You may already know, but I've been reading about FDU failures and apparently because there's so little fluid (less than a quart as I understand it) in there that any leaking can be a big problem.
A shockingly small amount! I just cleaned the area front/rear and will watch it over the next few days. Going to order oil, top off, and wrap tape around the plugs before putting them back in
Definitely concerned about it considering the amount of wheeling I do + I love deep water crossings
RC Bronco
Rob
Kansas
Guess not just one side making the noise even if I push up down on drivers side will make the noise.
That’s a serious clunk. Are the upper shock tower bolts loose?
I had a sound just like that and my right front shock bolts were loose
RaceRed24
RaceRed24
Shawn
New Brunswick
2024 Ford Bronco
Sound almost reminds me of basketball bouncing on the floor
RC Bronco
Rob
Kansas
The way you’re shaking it is the exact same shake I did when I finally figured out it was the upper shock bolts
GI_Jo_Nathan
Jonathan
I do have some big plans coming in September - solo into the Arizona Strip to wheel and camp along the West Rim and North Rim. Might purchase a spare CV axle to bring, just in case
Thank you both ( @Brian_B ) for the input!
I have my stock ones laying on a shelf in my garage, not sure if would be worth the shipping. I keep meaning to list them and my non-FAD M190 to get rid of them.
I looked all over for cheap used spare cv's for my Moab trip. Finally gave up and used Ford points on the Ford Performance painted ones. The regular ones were always out of stock at the time. This was for the M210 of course.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
That still sounds like a loose sway bar link to me. That is a metal on metal. Rule out shock tower on your coil pack by feeling for movement on top when you bounce it.
Im sure this is frustrating......
RaceRed24
RaceRed24
Shawn
New Brunswick
2024 Ford Bronco
I only feel it along the bottom . I’ll take better look at sway bar links as seems be more if tilt to one side slowly . Going over bumps on highway or straight don’t hear it.
wildtrak whitey
ely4646as
Bronco, Wrangler, Ram 2500
My truck had a very similar sound during very similar use cases. Upper shock mount was loose. No idea what the torque specs on our broncos are, but many shocks aren't torqued near as tight as you would think.
Good luck
RaceRed24
RaceRed24
Shawn
New Brunswick
2024 Ford Bronco
Would you think more likely sway bar links if is more prominent if it’s shifting side to side? I can get it to make noise on both sides shaking . It seems more noticeable slowly going over uneven ground .
I don’t notice much vibration in the top area of shock towers . I just notice vibration more through lower control arm by feeling if hold my hand on while moving.
Wife has bronco at work right now but plan on going over some more later on.
GI_Jo_Nathan
Jonathan
Could disconnect the anti-sway bar at the control arms and zip tie it out of the way to verify that maybe.
