- Ron
- May 24, 2021
- 15
- 125
- 332
- Thornton, Colorado
- 2021 Black Diamond 2022 Mini Cooper S
- Black Diamond
Installed my Mishimoto catch can this morning. A bit more time consuming than I had originally anticipated but not bad. Had a couple of brain-stumpers that held me up so I'm here to help the rest out there with what I learned.
Follow the Mishimoto instructions with assembly of the catch can / bracket assembly. Mount the can and attach the hoses.
Next chock, emergency brake and jack up the driver front wheel. You're gonna want that sucker off for access.
Remove the wheel and fender liner. Not mentioned in the included install instructions. You'll then be able to see the air/oil separator attached to the driver side of the motor.
The return line is at the top of the motor, just inboard of the brake reservoir, between the 2 white fittings. Push the gray button and pull the fitting off. It should release easily. If not, push in while pressing the button. This will help you get the other side off.
Behind the steering shaft you'll see the lower fitting. Using a long reach trim tool with a hook on it, pull the small blue tab towards you as you pull the hose off. took me forever to figure out how the tab works. 1, because no one has mentioned it, 2, because you can't see it until it's off.
Once that's done connect the "in" coupler to the lower connection using long pliers to get in there and push it on. Connect the "out" coupler to the upper connection and put everything back together.
Total time with the few tips should be approx. an hour.
Hope this helps. Feel free to hit me up with any questions you may have.
