New Bronco Big Bend 2doors Check engine and 4wd fault
Ptremblay1
Philippe
Canada
Golf Alltrack, Mercedes 240D
Just got my bronco today
Drove for about 80 km then I got the 4wd fault then a check engine a few miles after. I have the 2.3l. I don't know what to think the truck is brand new and failing.?
Ford Bronco New Bronco Big Bend 2doors Check engine and 4wd fault PXL_20220309_234047880 (1)
LowerSlowerDelaware
Lee
Lewes, Delaware
Subaru Outback, Chevy S10 Ram 3500
Sacre Bleu! You're driving Canadien! Maybe your Bronco doesn't like that Économie d'essence, eh?
Sorry! J/K. Probably something was missed during dealer prep. You need the codes to be sure. Unfortunately, back to the dealer in the morning
Ptremblay1
Philippe
Canada
Hahaha you got me :) I will report back. Merci mon ami!
Ptremblay1
Philippe
Canada
Seema it's the turbo overflow vent.. they will chane it tomorrow and hopefully I'll be on my way.. we'll have 2 feet of anow tomorrow night
Just_Jim
Minnesota
2021 Big Bend
Mine did the same thing @ 60 miles on the clock as I drove the 110 miles home after picking it up.
Carl Sagan
Brando
Huntington Beach
2022 Ford Bronco WIldtrak HOSS 3.0
Might need a new battery. I’ve seen that happen on other fords with a battery that needs replacing. The Broncos have been sitting for a bit on ice/dirt mtn
Ptremblay1
Philippe
Canada
Good to know it happen to another than me What a déception after waiting for so long so happy to drive it and then .. came the lights
Did you get bote the wrench and th check engine?
Thanks
Ptremblay1
Philippe
Canada
Mire was produced end of January you think the battery migh be the culprit whiteout any other sign?
Just_Jim
Minnesota
2021 Big Bend
Yep, wrench and SES with no cruise control. Took 2 weeks to get in to service to diagnose it, then 3 to get the turbo. I had 1700 miles on it before it got fixed.
Carl Sagan
Brando
Huntington Beach
It’s possible and hope that is the problem so it can be fixed ASAP for you.
Ptremblay1
Philippe
Canada
So I got back the truck 40 miles later the wrench appeared again. Went back to ford the senior mechanic took a look and played with the control arm of the turbo exhaust vent.. he found it hard to move, so he played with it until it was easy to move.. Problem solved. Will see if the problem reoccurs.
Thanks for the advice here!
Merci beaucoup!
