Even though this M&R light kit involves some trimming, it makes one awesome upgrade to the STANDARD plastic bumper.
Fits only plastic Standard Bumper The M&R 2021+ Ford Bronco light kit is installed neatly in the plastic front bumper to BEEF it up with strength and performance. The metal plate is made out of 11 gauge steel and is powder coated texture black. It definitely was designed to look OEM. Made with carefully selected materials, rated to last up to 100,000 hours! A IP68 waterproof build provides a robust durability capable of off-road use to live up to your Bronco's high performance expectations.
This kit includes the Driver and Passenger sides (1 order per Bronco) Houses (2) 40watt LED pods and (2) 10in Lightbars
40watt pods - White light with Amber DRL or Amber Light with Amber DRL
10in light - Amber or White
Includes a metal shroud that is powder coated and color matched with the factory Bronco bumper to give it a "built in look."
Includes all mounting hardware Can be purchased with parking sensors or without Comes with a wiring harness for 3 power sources to connect to AUX switches *CUTTING AND TRIMMING IS REQUIRED. **Please note that this product is for offroad use only. Please check your local regulations about street use.
