- Josh
- Apr 25, 2022
- 511
- 684
- 201
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ORACLE Lighting 4211-003 Fits 2021-2024 Ford Bronco LED Illuminated Wheel Ring 3rd Brake Light
Available here: https://ticklemybronco.com/products/ab-orc-fb-4211-003?_pos=1&_sid=6a2d33bfd&_ss=r
Code : AN5
This vibrant illumination behind your spare tire is guaranteed to grab the attention of everyone around -- either with a brilliant red brake light or any color imaginable displayed. The red brake light provides more safety and visibility while the ColorSHIFT® option allows you to match your other color-changing accessories. With a universal fitment, the brake light ring has a 13-inch diameter and mounts to the spare tire carrier.
A great-looking modification with real functionality, your trail partner can spot your Jeep a half-mile ahead! Improve your rear brake light illumination and get a customized look with this Jeep spare tire ring. Transform the look of your Jeep's rear end, and enjoy an easy install of this brake light ring with the provided hardware.
The extended brackets mount to the spare tire carrier. The wiring is easy; simply tap into your existing third brake light wire. (NOTE: Only red can be used as a third brake light. ColorSHIFT® can be tied into existing wheel ring wiring for power.)
Fitment: 2021, 2022, 2023, 2024 Ford Bronco
Code : AN5
