Outerbanks Front Camera not working
Adelaney
Amy
202!Bronco
My front camera is not working on my 2021 Bronco Outerbanks Advanced.
I’ve looked through settings and I’m not seeing anything regarding this issue.
I’ve also examined the camera itself and do not see any apparent damage or disconnect (I have not taken it apart)
I run in “Normal” mode most of the time.
Any input before I contact the dealership?
Ford Bronco Outerbanks Front Camera not working IMG_6190
JohnnyBronco
Pennsylania
X4
Have you mounted anything to the front bumper that would block it?
Didn't get a flash ice storm? Ice sleet slush will block cameras and sensors.
mcinfantry
Lee
Louisiana
Badlands 2 door
Mine flickers and cuts out, it has since i got it, and its been replaced
Adelaney
Adelaney
Amy
202!Bronco
Adelaney
Adelaney
Amy
202!Bronco
I’ve only had it for a few weeks and nothing mounted to block it.
I don’t recall noticing it when I purchased it as I’m brand new to anything Ford!
I live in GA and we haven’t had any of that type of weather ☺
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there. I can look into your Bronco’s camera concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
RickDeckard
Kentucky
I had this happen after a software update.
PartsForBlue
Jeremy
LAX
'21 Two Door
Had this problem for 15 months since it was new, finally left it at the dealer for a week and it got fixed.
6 months since the fix and all good. I think the wire was replaced.
Tex
Cliff
San Angelo
Mine does this occasionally, I get out and slap the front camera a couple times and it starts working again. I think it just wants attention.
flattops
Littleton, Colorado
Mine is having this same issue now. Bronco is only a week old. Any suggestions?
Adelaney
Adelaney
Amy
202!Bronco
@Ford responded and had me take it in to the dealer which I did. I'm still awaiting a call that the part came in. I took it in on May 2, and it is June 5, so I'm not sure what is going on and plan to call then tomorrow.
Bellime
Keith
2022 Ford Bronco
So the connection to the camera is on the passenger side at the top of the grill. The brown connector, it also has a fluid line for spraying the lens.
Ford Bronco Outerbanks Front Camera not working IMG_1763
if you had any work done on the front end, check this
