RH4x4: Full Feature Bronco Rock Sliders in 3 Flavors
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
Rock Sliders should do more than just look like a step. They should be strong enough to lift your Bronco off the ground with, actually function as a step, and be easy to install. So we made ones that do all of the above.
Available for the 2 door and 4 door Bronco, our Bronco Rock Sliders check every box for off road use and on road comfort.
Each slider is built out of .120 square tubing and then welded to .120 1-3/4" round tubing rails. We offer them in 3 variations: angled up for a classic offroad look, flat step with dimples for the largest step on the market, and angled down for a easier reach.
Because we install to your pinch weld, your floor pan (existing holes, no drilling) and your body mounts, you can use our slider rails as hi-lift jack points.
Our rock sliders ship powder coated black (bare steel available upon request) and are 100% Made in the USA.
2-door:
Angled Up
Flat Step
Angled Down
4-door:
Angled Up
Flat Step
Angled Down
Ford Bronco RH4x4: Full Feature Bronco Rock Sliders in 3 Flavors RH-60104-2T
Ford Bronco RH4x4: Full Feature Bronco Rock Sliders in 3 Flavors RH-60104-3T
jacobrdoty
Jacob
Sacramento, CA
2013 Mustang GT (Bagged and Boosted) x 2022 Bronco
I like! Great job using 3 styles of mounting before heading into the 4th- welding.
Seem's great!
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
These look great. It's so hard finding good sliders for the 2D Broncos.
Question: Do these have Hi-Lift jack points?
If not, will the outside part of the rail support the hi-lift with the proper attachment?
ROCK HARD 4X4
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
You would use the tube as your lifting point.
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
These go on my list.
