- Josh
- Apr 25, 2022
- 376
- 533
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Rigid Industries 46724 2021-2022 Ford Bronco Roof Line Light Kit with a SR Spot/Flood Combo Bar Included
This RIGID Roof Line light kit is designed specifically for the 2021-Present Ford Bronco and allows for a clean install of RIGID's high output LED lighting. This Roof Line light kit includes two roof line bar brackets, isolation bases, stud covers, a 40 Inch SR-Series Spot/Flood Combo light bar, solid black light covers, and a wiring harness.
Own The Night with RIGID's complete Roof Line LED light kit for your Ford Bronco.
Features:
Features:
- 2021-Present Ford Bronco Roof Line Light Kit with a SR Spot/Flood Combo Bar Included
- Complete Roof Line LED Light Mount Kit
- Stainless Steel Construction
- UV and Abrasion Resistant Powder Coat
- Alloy Housing and Heatsink
- Integrated Thermal Management System
- Impact Resistant Polycorbonate Lens
- Over/Under Voltage Protection
- RFI/EMI Protection, Reverse Polarity Protection9-36 VDC Operation
- RoHS Compliant
- IP68 Compliant - Dust/Water Ingress, Operating Temp -40 Deg F To 145 Deg F
- SAE J575 Compliant - Shock/Vibration
- Pressure Equalizing Vent
- Waterproof Connector
- 50,000 Hr Plus LED Lifespan
- Limited Lifetime Warranty
- Off Road Use Only
- Professional installation recommended
- Fits: 2021-Present Ford Bronco
- Roof Line Bar Brackets
- Isolation Bases
- Stud Covers
- Mounting Hardware
- 40 Inch SR-Series Spot/Flood Combo Light Bar
- Universal Wiring Harness
- Black Light Covers
- Resonance Dampener
