- Josh
- Apr 25, 2022
- 511
- 684
- 201
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ZROADZ Front Bumper Fog LED KIT, Includes (2) 3 inch Amber LED Pod Lights and (4) 3 inch White LED Pod Lights For 2021-2022 Ford Bronco
2021-2022 Ford Bronco Front Bumper Fog LED KIT, Includes (2) 3 inch ZROADZ Amber LED Pod Lights and (4) 3 inch White LED Pod Lights - Part # Z325401-KITAW Features & Benefits: Front Bumper OEM Fog LED Kit with White and Amber Pod Lights Sold as a complete kit, Includes: (4) 3 Inch White ZROADZ LED Pod Lights, (2) 3 Inch Amber ZROADZ LED Pod Lights, mounting brackets, wiring harness with fusible link, relay, toggle switch, all necessary hardware 1712 Lumens, 20 Watts, CREE 5W LED Chips per pod light Flood Beam, IP68 and IP69K Protection Rating, 50000 Hour Life Span Mild Steel Easy, bolt-on installation, no drilling required Low-gloss textured finish Limited lifetime product warranty, 3 year warranty on the finish Manufactured by ZROADZ Off Road Products in Corona, California.
Made in USA Kit includes (2) individual wiring harnesses that allow for separate wiring and control of the white/standard and Amber LED pods Also available as bracket only, see part number Z325401 or with white pods Z325401-KIT, or amber pods Z325401-KITA Fits Heavy Duty Modular Bumper Models Only ZROADZ Front Bumper LED Mounts and kits are a quick and easy way to add forward facing lighting to your vehicle.
The simple bolt on installation uses factory bolt locations and provides significant auxiliary lighting. Typical installation time is under 30 minutes and can be successfully installed using common hand tools by even the most casual enthusiast. ZROADZ Front Bumper LED Mounts are available in complete kits with light and wiring harness, or as brackets only for mounting common and popular LED light bars. ZROADZ Front Bumper LED Mounts are designed and made in USA. SKU:Z325401-KITAW Item #:Z325401-KITAW UPC #:609579042574
Year Make Model Submodel: 2021 FORD BRONCO BADLANDS 2021 FORD BRONCO BASE 2021 FORD BRONCO BIG BEND 2021 FORD BRONCO BLACK DIAMOND 2021 FORD BRONCO FIRST EDITION 2021 FORD BRONCO OUTER BANKS 2021 FORD BRONCO WILDTRAK 2022 FORD BRONCO BADLANDS 2022 FORD BRONCO BASE 2022 FORD BRONCO BIG BEND 2022 FORD BRONCO BLACK DIAMOND 2022 FORD BRONCO OUTER BANKS 2022 FORD BRONCO WILDTRAK
Finish: BLACK Installation: BOLT-ON Material: MILD STEEL Series: FRONT BUMPER OEM FOG Type: LED KIT
