- Josh
- Apr 25, 2022
- 376
- 533
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ZROADZ Front Bumper Top LED KIT, Includes (4) 3 inch White and (2) 3 inch Amber LED Light Pods For 2021-2022 Ford Bronco Z325431-KITAW
2021-2022 Ford Bronco Front Bumper Top LED KIT, Includes (4) 3 inch ZROADZ White and (2) 3 inch Amber LED Light Pods - Part # Z325431-KITAW Features & Benefits: Front Bumper Top LED Kit Sold as a complete kit, Includes (4) 3 Inch White ZROADZ LED Pod Lights, (2) 3 Inch Amber ZROADZ LED Pod Lights, mounting brackets, wiring harness with fusible link, relay, toggle switch and all necessary hardware 1712 Lumens, 20 Watts, CREE 5W LED Chips per pod light Flood Beam, IP68 and IP69K Protection Rating, 50000 Hour Life Span Mild Steel Easy, bolt-on installation, no drilling required Low-gloss textured finish Limited lifetime product warranty, 3 year warranty on the finish Manufactured by ZROADZ Off Road Products in Corona, California.
Made in USA Also available as bracket only, see part number Z325431 or with white pods Z325431-KITA Fits Heavy Duty Modular Bumper Models Only Does not block factory Bronco Grille letters Does not block factory front view camera ZROADZ Front Bumper LED Mounts and kits are a quick and easy way to add forward facing lighting to your vehicle. The simple bolt on installation uses factory bolt locations and provides significant auxiliary lighting.
Typical installation time is under 30 minutes and can be successfully installed using common hand tools by even the most casual enthusiast. ZROADZ Front Bumper LED Mounts are available in complete kits with light and wiring harness, or as brackets only for mounting common and popular LED light bars. ZROADZ Front Bumper LED Mounts are designed and made in USA.
