Soft top brackets
Hugh0512
Hugh
NY
I have a 2025 big bend. When I fold the top all the way to the trunk, there is some play in the brackets. More on the driver side bracket. I’ve tried strapping them so that there is no play, but no luck. Is it normal for the brackets to have play after clicking the bottom bracket into place? The only reason I ask is because it makes some noises when I’m driving. Like clicking noises. Thanks!
DavieO
2024 Bronco
Mine has a little play as well. I strap it down to eliminate the rattles.
Going to try placing a piece of foam there.
irishmurph01
Pat
26’ bronco heritage
Are the mounting brackets locked down? Behind the trim pieces.
Hugh0512
Hugh
NY
irishmurph01
Pat
26’ bronco heritage
These two brackets on the rear quarter panel is what I’m referring to.
Ford Bronco Soft top brackets IMG_2244
Ford Bronco Soft top brackets IMG_2245
