SS3 3" LED Pods | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Ford Bronco SS3 3" LED Pods | Diode Dynamics WZ6xs5v
Diode Dynamics is pleased to offer our Stage Series 3" LED pod!
Featuring higher output intensity than any other 3” light on the market, these LED pods have been designed for maximum functionality, with custom-engineered TIR optics shining in highly useful beam patterns, all in a durable package.
Ford Bronco SS3 3" LED Pods | Diode Dynamics BzrB9bl
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS3 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
Ford Bronco SS3 3" LED Pods | Diode Dynamics dR7OQbW
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series 3" serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series 3" is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Functional Patterns. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
SAE Driving is designed to supplement your high beams, but it’s great for general illumination as well. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to fully illuminate the road ahead at high speeds.
SAE Fog uses our distinctive FineLine optic design, and provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of cool white or yellow, which is often said to help cut through inclement weather.
Flood pattern was designed to provide uniform, even illumination with a full 60x60 degree spread of light. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It is perfect to use as a backup light, for lighting up anything at low speeds, or for trailers and worksites.
Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 65x25 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
Spot is an unmodified pattern, shining light directly from the TIR optic. The result is a highly focused 6-degree beam of light, perfect for directing light far into the distance. With an incredible output of 151,000 candela, the SS3 Sport shines a half-mile away (¼ lux), from a compact 3-inch package. NOTE: The Pro Spot uses a slightly larger emitter which spreads the light output more than the Sport Spot, resulting in a lower candela and lux rating even at a higher power level.
Ford Bronco SS3 3" LED Pods | Diode Dynamics WFrF1yt
Ford Bronco SS3 3" LED Pods | Diode Dynamics LeHcFcT
Not just off road. When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use.
Ford Bronco SS3 3" LED Pods | Diode Dynamics 4QOyze4
For states that require them, we also offer snap-on covers for your SS3 Pod. These covers are available in a variety of colors and keep your SS3 Pod clean and protected from dirt, dust, or whatever else the road throws your way! Please check your local laws and regulations for aiming, installation, and applicability.
Interchangeable Lens. Need a different beam pattern or color? You can swap it yourself! We offer replacement lenses that allow you to change the color or optic of your Stage Series SSC2 Pods.
White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Sport, Pro, or Max. Stage Series LED pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses high-intensity LEDs and is the best bang for the buck you’ll find. The Pro model steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, for both high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
Ford Bronco SS3 3" LED Pods | Diode Dynamics Ex85tGG
Backlight Functionality. The Stage Series 3" LED Pod is now available with a distinctive backlight, in your choice of white, amber, red, and blue. This integrated backlight gives you an additional accent light, along with the main beam. The SS3's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products. To power the backlight, use the included harness to tap your desired vehicle function.
NOTE: If you are upgrading your SS3 Pods to Backlit SS3 Pods, you will need to purchase a 2-pin to 4-pin wire tap kit in order to connect your existing 2-pin harness to your new backlit SS3 Pods.
Ford Bronco SS3 3" LED Pods | Diode Dynamics E0PDsZD
Simple connections. All SS3 LED pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Light Duty Dual Output Harness can be used to power up to two SS3 pods. If you are looking to power more than two SS3 pods, we recommend using our Heavy Duty Dual Output Harness along with a Deutsch DT Splitter.
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, we'll be more than happy to help!
Monday-Friday 10 a.m.- 5 p.m. CST
Email: contact@diodedynamics
Phone: 314-205-3033
Did you know? All US forum members are eligible for a FREE SHIPPING code! Just send us a direct message.
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
🚨 Our Memorial Day Sale is LIVE!!! 🚨
➡ Up to 15% OFF Sitewide
➡ 10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
⏳ ONLY 3 DAYS LEFT TO SAVE! ⏳
➡ Up to 15% OFF All Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ FREE US Shipping on any order over $300!
No coupon code is required.
Click HERE to shop lighting upgrades for your ride!
🚨 Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code 🚨
John C.
Diode Dynamics
Phone: 314-205-3033
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Psyched to get a pair of these mounted on my new DV8 FS-15 Rear Bumper. I am interested to see where folks have been mounting the toggle switch in their Broncos.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Ignite your lighting game this July 4th!
➡ 20% OFF Single Row Stage Series Light Bars
➡ 15% OFF Sitewide
➡ 10% JL/JT Elite Series Headlights
Plus, score FREE shipping and a FREE Diode Flag Tee with any purchase over $300!
NO COUPON CODE REQUIRED
https://www.diodedynamics.com/ ⬅
Expires at 11:59 p.m., Friday, July, 7th, 2023.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
It's our LAST SALE of the summer!
Save BIG on premium US-assembled lighting sitewide!
The time to upgrade is NOW!
➡ 20% OFF Single Row Stage Series Lightbars
➡ 10% OFF Sitewide
➡ FREE US Shipping on orders over $300!
The sale ends Friday, 9/8.
*Exclusions apply. While supplies last.*
CLICK HERE TO SHOP YOUR RIDE AND SAVE!
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool on our website! Simply enter the year, make, and model and all options will appear.
Ford Bronco SS3 3" LED Pods | Diode Dynamics WEWWfNf
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
It's your LAST CHANCE!
Save big on your favorite lighting brand with the summer’s LAST sale! From off-road lighting to LED Interior bulbs, we've got your vehicle covered from bumper to bumper.
The sale ends TONIGHT at MIDNIGHT.
Click HERE to shop!
tiltis23
Tim
Paris TX
2022 Bronco Outer Banks
well crap, Missed the Labor day sale... are y'all going to be having any more sales soon? Really interested in the SS3 Pods,
Thanks
WT205
Alabama
BMW
Thanks
If it makes you feel better- the discount on the SS3 pods wasn’t that much. They run sales about 6 times a year.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Thanks
Hey there!
Unfortunately, we only have 1 sale remaining planned for the end of the year.
However, you can always direct message us for a free US shipping code!
That's correct, we only offer a couple of sales per year. However, it's likely next year our sales will be more limited compared to the past.
Black Friday may be best sales of the year.
You aren't wrong there!
We offered up to 30% single-row stage series light bars last year :eek:
