Suspension Upgrade for Street Driving
LPBronco
Kreig
2022 Ford Bronco
A little different post about suspension upgrades as Michigan roads are terrible! I have installed a 1 inch level with Falken/RTR wheels and find the ride a little rough, any suggestions on a suspension upgrade for a better ride on roads/highway? I would like to lift a little higher as well, but this Bronco will spend very little time off road. Thanks in advance!
greatlakes
Grand Rapids
67 Buick Special
Is it a standard Big Bend or sasquatch? Also, have you checked your tire pressure? Mine were filled to like 45 lbs., so lowering it helped with our lovely roads.
LPBronco
Kreig
2022 Ford Bronco
Thanks, Big Bend non sas, pressure is as recommended for tires. Feel like I want to upgrade from Hitachis, but not sure what's overkill as it's not going off road often.
rguest3
Raymond
Florida and Virginia
F-350, F-450, 2022 Bronco, (2) 77 Broncos
The recommended tire pressure is usually set at maximum load weight for the tire. This recommended pressure is on THE TIRE. 35PSI is the recommended max for most C rated tires. No need to go higher than this EVER. The Bronco is a relatively lite vehicle and does not need the Max Load required PSI unless you are fully loaded. 32 PSI is a good starting point (Maybe Lower) and much more comfortable.
