Sold: Washington D.C. Tackform Tablet Fast Track Dash Mount
Roofus
Swamp
M3/Bronco
Asking $40 + shipping obo.
Ford Bronco Tackform Tablet Fast Track Dash Mount IMG_4811
Ford Bronco Tackform Tablet Fast Track Dash Mount IMG_4835
Ford Bronco Tackform Tablet Fast Track Dash Mount IMG_4812
  • Securely Mount To Your Fast Track™ Bracket: Featuring a 20mm ball, our CNC machined Fast Track™ ball mount is designed to work specifically with our Fast Track™ brackets, ensuring compatibility and ease of use. Built To Outlast You!
  • Tablet Compatibility: Our unique spring housing design is one of the few options on the market that can accommodate virtually all tablets, including Samsung Galaxy devices and iPads ranging from the iPad mini to the iPad Pro. This also includes devices with screen sizes ranging from 7” to 18.4”. We achieve this by bundling our spring cradle with 10 different legs to accommodate various-sized devices. The spring-loaded cradle can expand from a minimum of 6.25” to a maximum of 11.5” wide. The beauty of this cradle is that it not only seamlessly supports your current tablet but is also compatible with future devices. (Please note that it does not fit the Galaxy View.)
  • Deep Grips: Finding a tablet mount to fit your device is one thing, finding a tablet mount to work with your large protective case is another. Our grips are over 1.25” deep making them work with most tablet cases out there.
  • Indestructible: Yep we said it. Where most Aluminum tube arms have the sockets simply glued into the ends, making failure over time a likely event, ours will never fail. The reason is simple. Quality Engineering. We designed an internal support system that ties the two dovetail/socket ends together, offering a solution you can rely on. If you have more than one vehicle in your fleet, and failure is not an option, Tackform is your only choice.
  • Premium Materials: Real Aluminum Tube. Glass Filled Resin Knob Molded over Stainless steel threaded inserts. Stainless Steel and Aluminum Internal supports. CNC Machined Aluminum Dovetail Socket Ends.
AndGerry
Tomas
2012 GMC Acadia Denali
Still available? How much to ship to 60707?
