Tape measurement request -- Width across the top of the MIC roof?
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #1
Can anyone provide the overall width across the top of the MIC roof? I'm assuming 2/4 door are identical.
And if you have the roof rack, the usable width of the crossbars....?
Much appreciated!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I was looking for this at one point too…I think I got the answer of 59” and 61” where it meets the body.
redone17
Cold Spring, NY
That must not be right…soft is 60” at the base and closer to 54” at the top.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #5
Some people aren't that adept with using tape measures..? Lol 🤷
I basically wanna know if I can fit a Tepui Foothill and a Yakima Skinny Warrior together up there. Looks like it won't be an issue (except weight!)
redone17
Cold Spring, NY
Similar reason I was inquiring. At this moment I’m waiting on exoskeleton solutions. I’m also shifting gears and might just use our ARB awning+room for our sleeping quarters.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #7
Never thought of that option... Sleep on a cot or something? 👍🏻
Boxer4
TRUCK
Wrote this back on 7-26. Maybe it will help you.
* UPDATED 7-26-21 ROOF OFF measurements
These are 2 door measurements.
Door on truck numbers-
48 1/2" wide x 31" high to the window belt gasket. Add about 2" in height for the kick up at the door pillar. Thickness is about 9" ( Exterior handle, interior panel, etc )
Front roof panels-
Driver - 32 3/4" front to back x 28 1/2" wide x 5" deep
* Passenger - 32 3/4" front to back x 31 " wide x 5" deep ( includes gasket )
* Back roof shell section-
Ford Recommends to keep the back Glass up during storage.
So-
Overall length at the top of the shell -front to back is 72" gasket to gasket ( window open )
and is 51 " at mounting flange.
Side to side width is 63"
Total height is 26" with 22" if the back glass is closed.
Regarding the height, there are 4 locating pins ( about 2" long that are mounted on the bottom of the shell's flange. They are included in these heights.
Take these as rough dimensions.
Do you plan to post CAD details?
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
38 1/2” ID
Thanks Boxer... This changes everything.
I mean, the Skinny Warrior and Foothill mount points aren't on the very outside width of each... And overall width of the roof should accommodate both... With some overhang outside of the rails. 🤷
