Tapping into tail lights
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
It’s exposed red and black wiring that needs to be crimped when connected.
Our kits and harnesses are designed for lights with connectors. We sell a variety of things. But I'd recommend you do is buy the following two harnesses and put a 2-pin WP connector on your lights. You need 1 of each of these two harnesses, they work together:
In-Line Pigtail: https://www.4x4truckleds.com/crystalux-wp-2-pin-in-line-bronco-tail-light-harness-2021-ford-bronco/
Harness: https://www.4x4truckleds.com/crystalux-wp-2-pin-reverse-harness-w-upfitter-control/
Braden
Nashville, TN
How would you recommend running this harness with upfitter control to the engine bay? Along the frame or a rock slider?
